Best Practices for Replacing Hydraulic Oil in a Concrete PumpGreat question! Here's a step-by-step guide on the best practices for replacing hydraulic oil in your concrete pump: 1. Bleeding the Hydraulic Tank FirstYes, bleeding moisture from the hydraulic tank is an important step in the process. Here's how to do it properly: - Place a drain pan under the drain valve at the bottom of the reservoir
- Open the drain valve and watch the liquid as it leaves
- When the liquid changes from water to clean oil, close the valve
- Note: Condensation can cause a small amount of water to accumulate daily, especially with dramatic heating-cooling cycles — it should settle to the bottom overnight
2. Step-by-Step Hydraulic Oil Replacement- Drain the old oil from the bottom of the tank
- Close the drain valve once fully drained
- Refill using a filter cart — pump new hydraulic oil from barrels using a filter cart
- ⚠️ If no filter cart is available, rent one — do not skip this step!
- Filter the new oil to meet ISO 4406 code 18/16/13
- ⚠️ Unfiltered new hydraulic oil is NOT clean enough — new oil contains more contaminants than manufacturers approve for their machines
- Change the main return filter before restarting the unit
⚠️ Important Warnings- Never use unfiltered oil — ignoring filtration can cause immediate or early trouble with pumps and valves
- If the oil appears milky, this indicates water contamination — simply replacing the oil won't solve the problem; you must find the source of the water
- Always use the same brand and type of hydraulic oil when refilling
Always follow Manufactures recommendations.
