| butcha | 04-25-2008 | comment profile send pm notify |
I'm gonna pump gunite for the first time and would like to know the do's and don't of gunite pumping. How big of a compressor do i need, how much time do I have before it goes off, and the best way to clean it out. Just a little worried cause I've never done it before. I have a gunite gun. |
| Joe | 04-25-2008 | reply profile send pm notify |
Ive never seen anyone do it with less than 150cfm on the compressor as for when it goes off depends on all the normal factors you dont want any more than 20% rebound if you have more than that mud is way to wet |
| aussiekiwi | 04-26-2008 | reply profile send pm notify |
GDAY; youll be right mate.only one rule for me.PRE PLANNING". carry spare nozzle caps.get loads say 20minetus apart yo start with,KEEP IN CONTACT WITH READY MIX SUPPLIER.IF THERES GUNNA BE A DELAY YOU WANNA KNOW ABOUT IT.Icarry some retarder or slow willie with me .DONT START PUMPING WITHOUT AIR ON YOUR GUN WILL WILL END AS USEFUL AS A CHOCOLATE TEEPOT.always be ready to clean your lines out cause when it starts goin hard its usually too late.ALWAYS SPRAY FROM THE GROUND UP.GRAVITY IS AN AMAZING HELP.ANY PROBLEMS refer back to rule number 1 PRE PLANNING.
GDAY; youll be right mate.only one rule for me.PRE PLANNING". carry spare nozzle caps.get loads say 20minetus apart yo start with,KEEP IN CONTACT WITH READY MIX SUPPLIER.IF THERES GUNNA BE A DELAY YOU WANNA KNOW ABOUT IT.Icarry some retarder or slow willie with me .DONT START PUMPING WITHOUT AIR ON YOUR GUN WILL WILL END AS USEFUL AS A CHOCOLATE TEEPOT.always be ready to clean your lines out cause when it starts goin hard its usually too late.ALWAYS SPRAY FROM THE GROUND UP.GRAVITY IS AN AMAZING HELP.ANY PROBLEMS refer back to rule number 1 PRE PLANNING. To clean out i blow the spray hose first.then the pipeline then the pump.
