| davidh | 10-02-2010 | comment profile send pm notify |
| green gold | 10-03-2010 | reply profile send pm notify |
Sorry no, but I would like to know how long one would last?? |
| FunnyBoom | 10-03-2010 | reply profile send pm notify |
I have. What would you like to know about them? |
| davidh | 10-03-2010 | reply profile send pm notify |
are they long lasting ? and how much bar are they rated to |
| "MUDDY" | 10-03-2010 | reply profile send pm notify |
Hard as hell to clean out. Never seen one plug tho. |
| Many | 10-03-2010 | reply profile send pm notify |
A thought Keep in mind the mudsnakes intended use.From my perspective it's this way.Used for colums,walls where rebar interfers with traditional methods.With that being said,the total amount of yardage through the hose is minimal,so it should last a good amount of time.A pump can then carry a hose at all times,eliminating wall pipes. Think about what that can do for the operator and company.It further reduces the operating costs,pump doesn't have to return to yard for pipe on second pour.This helps cut redunant costs of operations.Safety,an ongoing battle,reducing chance of injury loading/unloading. In my humble opinion,a great tool for all involved |
We have only put about 1000 yards or so through ours so far but I can't see it lasting any more than 10,000 or so. Depending on the mud your putting through it. We have crushed granite which is pretty harsh. It is great for tall walls. I don't like it too much for tight rebar though. |
I will check tomorrow about the pressure rating but I think they are actually rated higher than a normal hose |
| WHO?? | 10-03-2010 | reply profile send pm notify |
I use a "Mud Snake" a lot,Love it!!!..It is great for what it is designed for...And cleaning one out is not that hard at all......What I do is I run a 3 foot double ended hose between my reducer and the "Snake"...When the pour is done,I recirculate my mud get it good and wet. Let the boom drain for a second,Disconnect the reducer from the boom,Leaving the cable hooked to the reducer,Let the reducer and 3 footer dangle just enough to kink off the "snake" fill the reducer and double ended hose with water.And Lift it into the air....Do that a couple times and BAM she's spotless...Oh and be sure to stuff a ball in your boom while you're at it!!! |
| custer | 10-05-2010 | reply profile send pm notify |
Won't do that in Cali.! |
| WHO?? | 10-05-2010 | reply profile send pm notify |
You know....You can do it above the hopper,Also if you just using a 10 foot "Snake" you can get away with just a reducer full of water...Meh whatever I'm just sayin |
| jbrown | 10-05-2010 | reply profile send pm notify |
where do you buy those hoses at |
