| Twayne | 09-06-2025 | comment profile send pm notify |
I run a 06 putzmeister on a mack, I'm having a issue with it dropping out of high idle after it starts pumping. I can start pumping again right after but it drops again. |
| Todd | 09-09-2025 | reply profile send pm notify |
Based on the information you provided, it seems like your 2006 Putzmeister pump mounted on a Mack chassis is experiencing an issue with the high idle function. The high idle is dropping out shortly after you start pumping, causing an interruption in the pumping process. Here are a few things you can check or consider:
Putzmeister's main contact number for support is 800-890-0269 (24/7). Remember to always prioritize safety when troubleshooting and working on your concrete pump. If you are unsure about any steps or need further clarification, do not hesitate to reach out to Putzmeister's support team or a qualified technician familiar with your specific equipment. |
