How Do You Select a Slurry Pump for Spodumene Lithium Processing?
tiiec 10-29-2026
What should you consider when selecting a slurry pump for spodumene lithium processing?
Spodumene processing involves abrasive mineral slurries at different stages, including grinding, classification, flotation, and tailings handling. Pump selection depends on slurry particle size, solids concentration, flow rate, head, and the chemical conditions of the process.
Which wear materials are suitable for lithium processing slurry pumps?
High-chrome alloys are often considered for coarse particles and severe abrasion. Natural rubber can be suitable for fine, abrasive slurries where impact conditions allow, while polyurethane may be an option for selected wear applications. The final choice should be based on actual operating conditions rather than the process name alone.
Is corrosion resistance important in spodumene processing?
It can be. Although many spodumene slurries are primarily abrasive, some process streams may have specific pH levels, temperatures, or chemical additives that affect material compatibility. Corrosion-resistant alloys, such as A49, may be considered for suitable conditions after evaluating the actual chemical environment.
Which slurry pump type should be considered?
Heavy-duty slurry pumps, such as the WX(R) series, can be evaluated for demanding mineral-processing duties. The appropriate configuration depends on the required flow rate, head, slurry properties, and wear conditions.
Ultimately, reliable slurry pump selection for spodumene lithium processing requires balancing abrasion resistance, corrosion compatibility, and hydraulic performance. Reviewing process data before choosing materials can help avoid premature wear and unnecessary maintenance.
Learn more about TIIEC heavy-duty slurry pumps: https://www.tiiec.com/products/heavy-duty-slurry-pump.html
