| Barroso Built | 03-31-2025 | comment profile send pm notify |
Hi my name is Joe I am a carpenter and builder and recently I have bought a cheap pump I'm slowly going through the thing and learning it's in a working. I have fully serviced it including new filters and all fluids I have come across an issue where at the end of a stroke the S tube overextends past before swinging back the other way I also have an issue where once its wings the other way it doesn't completely align with the second material cylinder it's about the thickness of the wall out please any pointers would be greatly appreciated I have attached a photo and a few videos the videos show the sequence from three different points of view ,one of the S tube 1 of the material cylinders and one of the pressure gauge I have gone through and made sure the material cylinders aren't bottoming out and The Adjustment screws on the rear roughly in the same position it seems to be pausing while the ram behind the hopper is compressing that extra little bit before swinging back the other way Thanks again |
| Todd | 03-31-2025 | reply profile send pm notify |
S-Tube Alignment IssuesBased on your description, you're experiencing two main problems with your concrete pump's S-tube:
Here are some troubleshooting steps to address these issues: Check S-Tube AdjustmentThe S-tube should be properly adjusted to align perfectly with both material cylinders. According to maintenance guidelines:
Verify Hydraulic System ComponentsYour symptoms suggest potential issues with the hydraulic shift circuit:
Proximity Sensor AdjustmentThe misalignment could be caused by incorrect proximity sensor location:
Check for Mechanical Issues
Operating Recommendations
If these steps don't resolve the issue, I'd recommend contacting a service technician. The Alliance Service Department can provide specific guidance for your model. Would you be able to share those videos or photos you mentioned? That would help provide more specific advice for your situation. |
| Barroso Built | 04-01-2025 | reply profile send pm notify |
Thanks for getting back to me. I will go through the steps and see what I can do. Here is a link to a video of the issue. Ive taken a video of behind hopper. Then behind material cylinders. https://youtube.com/shorts/muFXK06W22c?si=9iXmFGM8DsvTiE4c |
| Todd | 04-02-2025 | reply profile send pm notify |
Let us know how it goes |
