Loop Belt 33 meter jobsite photos
JGBelt 10-14-2015
LB33 pouring stone, then concrete footings in same set-up.
Z-Boom_Parks 10-24-2015
Love that paint job!
JGBelt 10-24-2015
This machine pictured weighed 66,360 lbs (30,100 kg)
If adjusted properly, conveyor belts can clean up very easily in about 10-15 minutes after a pour. Here the operator just cleans the hopper with the on board pressure washer. Water will go up the belt and pre clean the transfer and discharge spout. Belts also have the ability to pour, rock, sand and any other aggregate type material which increases the machines utility. Horsepower requirements per m3 of material placed is generally much less than a comparable concrete pump.
JGBelt 10-27-2015
Hello Dipstick. The remote control system is not Datek. It is Scanreco, also based in Sweden.
We have had very good performance with this system so far.
Beast 10-27-2015
yeah we love those remotes they are awesome
2park 11-02-2015
it wouldnt be compairable to a 33m  a pump is measured straight up this machine would be more like a 36m
JGBelt 11-18-2015
Under roof pour. Schwing pump feeding a Loop Belt feeding a Somero laser screed.
Farmboy72 11-18-2015
That's what you call teamwork!
JGBelt 11-19-2015
The teamwork is even more meaningful because there are three Oury brothers involved with this equipment.
Tom at Schwing, Peter at Loop Belt, and Leo at Somero.
Way to go brothers...rockin' it in concrete. Pumping, Placing and Finishing!!!
