| b-alto | 06-20-2015 | comment profile send pm notify |
On my 02 Mack i am having intermitent clutch release issues. Sometimes my clutch pedal wont release the clutch. Its like the inner throw out bearing is not getting forked, but then after i take off down the road and pump it a few times works fine again. The cable and swing arm seem to be working. Any one ever pull the trani plate off and work on this issue? |
| greenguy | 06-20-2015 | reply profile send pm notify |
we've had the same problem on a couple of trucks. Hate to say it, but the only consistent fix we found was a new clutch.....I've got a couple of old ones kicking around that look perfect but intermittently don't release....no clue why |
| b-alto | 06-22-2015 | reply profile send pm notify |
Thanks Greenguy, I talked to Mack and they said its a broken spring on the clutch. i'll have to replace the clutch.
| Boomerr | 06-24-2015 | reply profile send pm notify |
Ya i had to replace mine last year it was doing the same thing. I had 2 springs gone on my clutch, Not cheap when they have to replace the output shaft and cross shaft. |
| b-alto | 06-27-2015 | reply profile send pm notify |
If anyone has this trouble starting get it fixed before it breaks and lets you down. Mine started working fine again and a week later i was very lucky, it broke at my shop yesterday after three pump jobs and a 200 mile trip. Good thing i know the best mechanic ever a guy that towed it and put the clutch in, all in one day. wow! |
