| barron | 04-10-2009 | comment profile send pm notify |
well I lost 30 feet of hose last week, due to cuts and and bulging.....anyone want to sell me some 2.5" hose, I'll take used system.....I've only got enough to go 150 feet...and I refuse to carry my big hose (4" and 5") and around seattle area... |
| bri | 04-10-2009 | reply profile send pm notify |
i know many ppl that can help u call me 678 600 3035 |
| barron | 04-10-2009 | reply profile send pm notify |
hey Too Tall, awesome, expect a call, I pump in your area from time to time.....I get calls to Sedro Wooley and down to Tacoma....sucks being slow |
| biged | 04-11-2009 | reply profile send pm notify |
Too Tall what size pipe fittings will I need to be able to line pump with my Putz, and what size hose do you use, I have a 5/45 Olin and use only 2 1/2 hose, I have some really good mixes that I use with my line pump very rarely plug, I have never tried using a Boom or never had to my Boom Pump sits still way to much. |
Let me see if this is what you use, 1- 5 inch metic 90, then 1 - 5 metic to 4 inch then 1- 4 inch to 3 inch then if I want to use my 2 1/2 inch hose I will need a 3 inch to 2 1/2 inch reducer, all reducers will have heavy duty ends and to control my out put or pressure select 6 gear my 2 1/2 inch hose is rated at 1100 PSI. When I'm pumping threw the boom I pump in 7th gear and RPM's at 1800, so in 6th what RPM's. And thanks for you help |
| barron | 04-15-2009 | reply profile send pm notify |
Got a hundred feet today....thanks again Isaac....I'm king of the world now |
