| iraklisani | 01-25-2009 | comment profile send pm notify |
Hi
I have some pressure problems with TK-70 and TK-100
On Tk-100 it's 2500 with small line ? on Tk-70 it's 2000 but once in evry 3 strukes it's getting 3000
please advice how can i adjust pressure
Thanks |
| FUNKY | 01-25-2009 | reply profile send pm notify |
MAYBE YOU HAVE MAIN CYLINDER PROBLEMS,EVERY SECOND STROCK TRYING TO MAKE UP |
ARE YOUR WEAR PARTS IN GOOD ORDER ? |
| sparky | 01-25-2009 | reply profile send pm notify |
wear parts are a consideration as is the pressure spring adjusment on the cutting ring. But a rpoper check of max. hydraulic pressures to make sure they are set to factory spec would eliminate the hyd. part of the pump from the equation. |
| pumpit | 01-26-2009 | reply profile send pm notify |
Just for heck of it just make sure that your anti short stroking system is working properly Putz Sure stroke |
| iraklisani | 01-27-2009 | reply profile send pm notify |
whare anti short stroking system is located so i could check it |
| pumpit | 01-27-2009 | reply profile send pm notify |
if you look at your electrical schematic there is a third prox switch on one cylinder that is supposed to hold that cylinder up (pressure out every third cycle to prevent short stroking it sounds to me as if its working properly but you will have to check schmatic to make sure |
