| Boomerr | 01-24-2015 | comment profile send pm notify |
The boom pressure is good and the filter was replaced. Any ideas? |
| hamed_dawn | 01-24-2015 | reply profile send pm notify |
What is the model? |
| gboom | 01-24-2015 | reply profile send pm notify |
Bomerr, we need more info...what pump model?what year? any repairs on the hyd. System lately? Did the problem show up all of a sudden? Any problems with another hyd system on the pump? |
| lucky phil | 01-24-2015 | reply profile send pm notify |
When the energiser seals get weak and will cause it to lift slower at times |
| Reco36 | 01-24-2015 | reply profile send pm notify |
hey Im also courious on this problem is it only one section or all the sections. is it when the oil is cold or hot. i found out when im haveing a problem with my pump think of all the conditions weather. rainy, damp, sunny, hot, cold, it helps when trying to figure out a random problem. |
| Boomerr | 01-24-2015 | reply profile send pm notify |
34 x 1999 Sometimes it is the turn and the 3rd retracting, it seems to be when the oil is 50-70 degrees running mv22 oil |
No hydralic pump problems but the boom movement has been slowing down over the last couple of years and the 3rd and turn started to move slower at times this summer 30 plus degrees. |
I think you should increase the delta P on the boom regulator. |
| brian6 | 01-25-2015 | reply profile send pm notify |
are your hand valves hitting the stops (or moving the entire distance the valve will go)? |
| gboom | 01-25-2015 | reply profile send pm notify |
Besides the delta P on the boom pump, check the pretension pressure on your handvalve, i am almost certain that will solve your problems |
| Reco36 | 01-25-2015 | reply profile send pm notify |
have you tried using the manual hand valves. when its acting up. maybe its a bad coil getting hot with use and starting to get weak |
| Boomerr | 01-25-2015 | reply profile send pm notify |
Thanks for all the imput, i will check these things out. |
