Stationary Concrete Batching Plant
junhua 05-08-2021
Stationary concrete batching plants are used for long-term projects or permanent facilities. It is designed to run well with the highest reliability and intensity in the harshest environments.
Most experienced concrete contractors will choose a stationary concrete plant to complete their work, because it provides the largest production capacity and the longest working time. Besides, its immense flexibility makes it possible to extend the plant at any time.
Junhua stationary batching plants are equipped with twin shaft concrete mixers or vertical shaft planetary mixers, with over 20,000 hours of the trouble-free operation time, and are widely used in various projects, especially for massive infrastructural and precast concrete projects.
Junhua also provides stationary batching plants equipped with two mixers which will double the production capacity and is suitable for larger projects.
Stationary Batching Plant Advantages
  1. Simple structure, low failure rate and easy to maintain.
  2. Suitable for long-term, high-load operation.
  3. Modular structure, flexible configuration and easy to expand.
  4. Have the ability to produce a variety grades of concrete by replacing components.
  5. The skip hopper stationary batching plant has a small footprint, short installation time and easy to relocate.
  6. The belt-type stationary batching plant has large capacity and low power consumption.
  7. Have a variety of optional components to meet production needs under different conditions(Heating and heat preservation module in winter, cooling and ice module in summer, etc).
HZS25 Concrete Batching Plant
  • Capacity: 25m³/h*
  • Power: 60KW*
  • Container Qty: 40HQ*1 + 20GP*1*
  • Price: 15000 - 38500USD*
HZS25 Concrete Batching Plant is also called as JS500 Concrete Mixer Plant. The standard configuration of the HZS25 batching plant uses JS500 twin shaft mixer, PLD800 2 bin batching machine, optional components include cement silos, mixer hydraulic control system, automatic control system, etc. HZS25 can be installed in very small places and is widely used in small infrastructural projects, precast factories, and block factories.
HZS35 Concrete Batching Plant
  • Capacity: 35m³/h*
  • Power: 75KW*
  • Container Qty: 40HQ*2*
  • Price: 20000 - 45000USD
The HZS35 Concrete Batching Plant or JS750 Concrete Mixer Plant is a skip type concrete plant that produce 35 cubic meters of concrete per hour. It is a one of the best-selling small batching plants, widely used in construction of buildings, roads, bridges, dams, railways and others. Thanks to its small footprint, durability, high cost performance and other advantages, HZS35 becomes an ideal choice for small organizations and private companies.
HZS50 Concrete Batching Plant
  • Capacity: 50m³/h*
  • Power: 105KW*
  • Container Qty: 40HQ*3*
  • Price: 32000 - 60000USD*
HZS50 Concrete Batching Plant is a medium-sized skip type compact stationary batching plant that equiped with JS1000 Twin Shaft Concrete Mixer, It produce 1000 liters of concrete per batch. It widely applied in ready mix and precast industry as well as in large block making plant. By equipped with different components, HZS50 batching plant can produce various grades of concrete.
