Which Slurry Pump Is Best for Mine Sump Applications?
tiiec 10-29-2026
What should you consider when selecting a mine sump slurry pump?
Mine sumps collect slurry, sediment, and abrasive solids that must be removed reliably. Pump selection depends on slurry concentration, particle size, required flow and head, sump depth, and installation conditions.
When should you choose a vertical cantilever slurry pump?
A vertical cantilever pump, such as TIIEC’s VC(R)/VCS series, is suitable for fixed mine sump installations. Its motor and drive remain above the slurry while the wet end operates submerged. This design avoids submerged shaft bearings and is well suited to many stationary sump and slurry collection duties.
When is a submersible slurry pump a better option?
A submersible slurry pump, such as the TIIEC SPS series, integrates the motor and pump into a compact unit. It can be considered for restricted spaces, deeper sumps, or applications requiring flexible installation and relocation.
How do you choose the right solution?
Neither design is best for every mine sump. Evaluate the slurry properties, operating requirements, available installation space, and maintenance access before selecting a pump.
For reliable mine sump slurry pump selection, provide your sump dimensions, slurry characteristics, required flow, and discharge head to help determine a suitable configuration.
Explore TIIEC slurry pump solutions: https://www.tiiec.com/news/mine-sump-slurry-pump-selection.html
