xforce1 | 05-19-2013 | comment profile send pm notify |
It pumps like a champ till it gets to around 45 degrees +/- and then it goes to barely stroking. Turn the strokes up to 10 and nothing changes for 10 or 11 strokes and then WIDE OPEN it goes till you throw the stroke knob down then back to barely stroking. We've replaced both filters and hydraulic oil along with the stroke limiter cartridge and coil. So the question is, has anyone had this problem and if so, what do I do next? Thanks |
Mister_Perkins | 05-19-2013 | reply profile send pm notify |
did you replace the soft-switch cartridge on the top of the brain? |
putz63 | 05-19-2013 | reply profile send pm notify |
It's the o rings in the soft switch. Check them and replace |
xforce1 | 05-19-2013 | reply profile send pm notify |
I did turn the quarter turn valve but didn't make a difference. I will try the o-ring and see what happens. I own the company and I'm not around this pump all the time and I've went with it a couple times but when I do, it don't mess up of coarse. Thanks for the info! |
Would them o-rings cause the temp to run warm? It gets up to 70 degrees even with the fan on. |
toper | 05-19-2013 | reply profile send pm notify |
i beleive so the o-rings were bad on the 52 i run and it.would.get hot and have stroking issues,the oil bypasses somehow.and doest cool off,mech. replaced o-rings and problem solved
gboom | 05-19-2013 | reply profile send pm notify |
You may have aproblem with the stroke limiter valve itself; first, plug in the cable remote to see if the problem still exist, if it goes away, you have an issue with the remote. If the problem is still there, you need to check the pressure, that controls the main hydraulic pumps, 8 out 10 times the electronic cartridge and solenoid that sends the hyd. Signal to the pumps is bad. |
70 deg C celsius does not seem really hot, when you run the pump, check the hoses for one that is hotter than all the others, usually a case drain hose out of the pump gets hot, when the pump is worn out; your soft switch is ok, unless you have a shifting problem |
service1 | 05-20-2013 | reply profile send pm notify |
By your description I would say you have a issue with the stroke limiter valve or a regulator on the hydraulic pump. You need to monitor the pressure at the stroke limiter valve. Call me with any further questions. Jeff Popa Technical Service Manager and Spare Parts Specialist Off – 651/429/0999 X 213 Direct – 651/653/4213 Cell – 612/845/6981
Mister_Perkins | 05-20-2013 | reply profile send pm notify |
this is why it's nice to have guys from the service department on this website |
b-alto | 05-20-2013 | reply profile send pm notify |
Yeah those Schwing guys are the best. The stroke limiter knob needs to be turned all the way up to keep full hydraulic function. I had a problem with a slow rock valve, turns out i needed to turn the SL up full. |
Schwing31ht | 05-21-2013 | reply profile send pm notify |
make sure you have 0 volts to 12 volts on your stroke limiter and 8 bar to 40 bar oil pressure. It can be a card or a chip on the main card or maybe just reajust your stroke limiter in your main card with a pressure gauge on the stroke limiter |
