MVCP | 09-04-2013 | comment profile send pm notify |
Ive got a request to line pump into a crawl space 80 yards of 1.0 sack. Is this possible with any additives.....extra air entrainment,slick packs, ect????? ?Any suggestions or advice |
b-alto | 09-04-2013 | reply profile send pm notify |
No way, it would be nice to pump sand but it doesn't work. |
thinksnow | 09-04-2013 | reply profile send pm notify |
ADD 300-400LBS OF FLY ASH THEN GOOD TO GO |
Mr.HighRise | 09-04-2013 | reply profile send pm notify |
three or four hundred pounds of slag works just as good, there is a lean mix in my area that uses no cement at all mainly slag with fly ash pumps like butter in fact best cdf mix I've ever pumped |
crete | 09-05-2013 | reply profile send pm notify |
Can anyone get that mix design and post it? |
Doug | 09-05-2013 | reply profile send pm notify |
No problem, we pump it everyday at an 8"+ slump through both booms and trailers. Pump continuous (re-circulate) or it will separate. If you need any slump or need to stop add two bags of bentonite to a load. If it it a slow job or lots of waiting make it a 3-4 sack with either flyash or cement. |
b-alto | 09-05-2013 | reply profile send pm notify |
How is it on wear parts? i used to pump agg lime and black dirt for slab jacking and it would wear my equiptment out at a 10 to 1 ratio? |
Beast | 09-16-2013 | reply profile send pm notify |
its gonna eat on your piston cups and cylinders, and all your wear parts , that much sand just eats up pistons especially if its hard to pump, we always do 400 lb cementuous material , doesnt matter if its slag,cement, or fly ash , it will all pump as long as its wet enough. |
