Seed | 03-14-2009 | comment profile send pm notify | |||
What are the odds of pumping a 1.5 agg mix through a 4" tip hose? This is a real nice blended mix! I like to call it " The Candy". Are the risks too great for a 4 " tip? 5.5 slump Seed |
Vasa | 03-14-2009 | reply profile send pm notify | |||
Joe | 03-14-2009 | reply profile send pm notify | |||
I defnitely prefer 5 inch hose with 1 1/2 rock less hassle and heck if you arent pushing the hose all more the reason to us the 5. I hate nothing more than plugging |
Seed | 03-14-2009 | reply profile send pm notify | |||
I am undecided if I should risk it! We are pumping at a pretty good clip so a clog could be lethal.
zuat150 | 03-14-2009 | reply profile send pm notify | |||
That should be no problem we do it in florida all the time 1.5 to 2" crushed rock. |
Telealbelt | 03-14-2009 | reply profile send pm notify | |||
Sometimes its the shape of the rock that determines the size of the hose. We do 1.5 with 4 hose but its round rocks. |
elkhunterz | 03-14-2009 | reply profile send pm notify | |||
my rule of thumb has been 2x the aggs plus an inch so 1.5x2+1=4.... your good! |
crete | 03-14-2009 | reply profile send pm notify | |||
I'm just a belt guy,why do you want to reduce down? |
bigstick | 03-14-2009 | reply profile send pm notify | |||
I always run a five inch tip hose unless i'm plugging into system, never worry about a plug. Maybe too old or too lazy to change. |
johnjohnjohn | 03-14-2009 | reply profile send pm notify | |||
5" always here in houston |
Drew AUS | 03-15-2009 | reply profile send pm notify | |||
Hey seed ! I think if you are even the slightest bit worried go with the 5 inch , see how it goes if it goes well try the 4 inch.. If your starting to doubt yourself stick to the safe option mate! |
ShortStik | 03-15-2009 | reply profile send pm notify | |||
it is recommended that pipe and discharge be 3x (4x is prefered) then the aggregate. if your pumping at a good rate...i'd go with the 5" |
Seed | 03-15-2009 | reply profile send pm notify | |||
Thanks Everyone! I think I may give the 4" a shot for the hose man! As I mentioned the mix is good with no extra chunks in it. The RM outfit if # 1. |
