"4.5"" pipe"
Bob 12-05-2005
I have been pleasantly surprised by the absence of pumping problems when using the 4.4 pipe. Mixes here in Atlanta are (compared to other places I have been) marginal at best. The 4.4 pipe is doing the job well. Now the wear is something else again. A set of the best of the best will need to come off @ 30,000yds or so (125mm) I dont even want to talk about the wear on the 4.4. It is simple: Velocity = wear. The same yph in 4.4 must travel faster than 125mm. Come to Atlanta...... ConForms will be happy :)This message was edited by Bob on 12-5-05 @ 3:17 AM
justanthrpumper 12-05-2005
You should try pumping in vegas
