oregonfan6285 | 12-04-2007 | comment profile send pm notify |
has anyone tried to put 5inch elbows on the end of a 61meter to take out some of the boom bounce? i heard it works. i have also heard that it pushes the liner of the 4.6 pipe into the 5 inch elbow so i am not sure if i should try it. |
OE Local 3 | 12-04-2007 | reply profile send pm notify |
I WOULD NOT . |
eugene | 12-04-2007 | reply profile send pm notify |
put a weld bead on the connecter end and grind it flat to hold the liner in posistion. |
The Cat | 12-05-2007 | reply profile send pm notify |
hi there i run a 63 and know what you mean about boom bounce.... i heard that putz are looking at a 119mm pipe to replace te 114mm that are on at the min...also have you to tried to pump just that little bit quicker it`s seems to level the bounce out a bit.. |
2IC | 12-06-2007 | reply profile send pm notify |
i'm with the cat, give her more stick, she'll flatten out. |
johnjohnjohn | 12-08-2007 | reply profile send pm notify |
for whatever reason the higher the volume the smoother it is. also instead of reducing stick with the 4.5 hose. that helps a little too. try full throttle and play with the volume until you get it where you like it when she's stretched. also i find that once you get the fourth section tucked under far enough,if you start a-framing that helps too. |
