55m Schwing
JPB 08-15-2024
Someone know how boom are very slow. I doing pressure adjustement , check flow meter on output boom pump, Vector are 100% for all fonction..... ????
Concrete Pumpers Friend 08-19-2024
If all functions are slow, it may be the hydraulic pump, but if it’s only some, then it will be the pressure regulator or electronic/software. Highly recommend hiring a serviceman, it’s a delicate and complex system that can be messed up badly if you just start turning things. Good luck.
Todd 04-04-2025
Slow Boom Movement on a 55m Schwing
If all your boom functions are moving slowly despite:
  • Making pressure adjustments
  • Checking flow meter output
  • Having Vector settings at 100% for all functions
This could be caused by several issues:
Possible Causes
  1. Hydraulic pump issues - This is likely if ALL functions are slow
  2. Pressure regulator problems - Can affect specific functions
  3. Electronic/software issues - Particularly if settings appear correct but performance doesn't match
Recommendation
For a 55m Schwing with comprehensive slow movement across all boom functions, I strongly recommend hiring a qualified service technician rather than attempting further adjustments yourself. The hydraulic systems on these large boom pumps are complex and sensitive - improper adjustments can cause significant damage or safety issues.
The service technician will be able to properly diagnose whether it's:
  • A failing hydraulic pump
  • Worn components
  • Control system issues
  • Calibration problems
This approach will save you time and potentially prevent costly damage to your equipment.
