accumulator nitrogen pressure ?? schwing 2002
Schwing31ht 05-22-2013
How check the nitrogen pressure on schwing 2023  ?
Mister_Perkins 05-22-2013
remove accumulator and hook a gauge to schrader valve. should have a 100psi pre charge
gboom 05-22-2013
It is 100 bar, not 100 psi (100 bar = 1450psi)
Boomerr 05-22-2013
Your accumulator pressure should be 200-180 bar and drop down to 100 bar when the rock valve switches.
Schwing31ht 05-23-2013
are you sure 100 psi or bar
Mister_Perkins 05-23-2013
MY mistake. Yes, its 100 BAR . lol , 100 PSI and you wont have a very good shift experience. It will need to be pretty wet to shift right. sorry about that
service1 05-23-2013
A quick check is to have the machine operational with the estops cleared and make sure you have the 200 bar hydraulic pressure on the accumulator hydraulic gauge. If you watch this gauge close when you hit an estop it will drop slow and at some pressure it will change its rate of dropping from slow to fast. the spot where it changes rate of dropping is an indicator of the nitrogen charge in the accumulator and if correct you will see this change around 100 bar. Contact me if you have further questions.
Jeff Popa
Technical Service Manager and Spare Parts Specialist
Off – 651/429/0999 X 213
Direct – 651/653/4213
Cell – 612/845/6981
jpopa@schwing.com
yeah the only reason i told him to remove it was because I was told the gauge on the deck was just for reference and was not 100% accurate. Could just be false information I was given though?
Who knows
Thanks so much guys and everything is ok on my pump.
