| MR. PERSONALITY | 06-04-2009 | comment profile send pm notify |
WONDER WHY PUMPS AREN'T MADE AIR RIDE IN THE BACK. HAVE BEEN GIVIN THE STORY OF HOW SPRING RIDE IS SUPPOSED TO HELP SUPPORT THE PUMP IN THE EVENT OF AN OUTRIGGER PROBLEM. I THINK THAT #%&?. WE HAVE PLENTY OF BOOM TRUCKS ALL AIR RIDE, NO PROBLEMS. THE BENEFITS OF AIR RIDE GO FAR BEYOND OPERATOR COMFORT. LESS SHOCK LOADING OF THE BOOM, INCREASED HOLDING VALVE LIFE.CONSTANT RIDE HEIGHT, AND BETTER OFF ROAD THAN THE SPRING RIDE SET-UPS WITH THE OVERSIZE BUMP STOPS. |
| Step Brother | 06-04-2009 | reply profile send pm notify |
I drove two that were all airbags no springs. Rode nice except when the wind blew and the truck would sway back and forth. 115,000 was to heavy in my opinion, as well as to top heavy. Can you get the airride on smaller pumps? |
| Many | 06-04-2009 | reply profile send pm notify |
This topic was brought up a while back.There was one operator out of Canada that said he had run one (52m) with airide and was scary as heck. |
| MR. PERSONALITY | 06-04-2009 | reply profile send pm notify |
WHAT MAKE? MAY BE THE SPRING RIDE THING IS JUST PUTZ. |
Don't quote me,but recall 52m schwing with a tor chassis.If I remember right he said that combination was all over the road,hard to handle. |
| murf | 06-04-2009 | reply profile send pm notify |
on the smaller machines, springs are on the outside of the chassis rails, air bags tend to be more central and can be in the way when mounting when allowing for the cylinders to drop through the chassis, its easier to therefore use a spring ride chassis |
| bigstick | 06-04-2009 | reply profile send pm notify |
Operated a 61 meter mounted on a TOR. Biggest piece of shit I've ever driven. All airbags on each axle, the chief engineer from schwing even came down for two weeks and could never fix it. Would never recomend this set-up for any truck. |
| local18 | 06-04-2009 | reply profile send pm notify |
We also have a 58meter mounted on a tor, your right bigstick nothing but problems with airride and truck. TOTAL JUNK!! |
| Pump N00b | 06-04-2009 | reply profile send pm notify |
Love my Mercedes Actros on springs. So much more stable and takes you places air would'nt dare to go. |
| pumper chuck | 06-04-2009 | reply profile send pm notify |
I run a 04/ 52m schwing on a mack frame/chasie, all air rears. handals great even on nc,s hwy 26 which is concidered one of the worst roads in the country.just wish steers was both air. |
| wheezer | 06-05-2009 | reply profile send pm notify |
Early air rides were little understood and often poorly set up. It is vital to have ride height adjusted and set fore & aft as well as left to right.Tire pressure must be correct in ALL tires and checked routinely. Current air ride suspension offers many advantages for pumps and should be considered for any unit above 40 meters. Do not confuse old ones and lack of knowledge to current units. Again check and equalize tire pressure, it will surprise you. |
| ShortStik | 06-05-2009 | reply profile send pm notify |
had air on the rears of a mack 6 axle. ripped them apart more then once. air is made for roads, not off-roads (in my opinion) |
