BRETTSKI | 04-13-2009 | comment profile send pm notify |
I'm running a 32m putz with black and white controls, it's really touchy any tips?? |
pumpit | 04-13-2009 | reply profile send pm notify |
try adjusting your stack valve handle stops if you regulate speed |
Red1 | 04-13-2009 | reply profile send pm notify |
You gotta slap it. Throttle down a bit and tap it. Some work better with "leaning into it" rather than slapping it. Its all just a matter of feel. You can also dial in the stack valves. Practice in an open field first. |
biged | 04-13-2009 | reply profile send pm notify |
I got a 1989 putz 32 slewing will always be touchy when fully extended,a few taps is the best get it out in your yard a pratice |
bri | 04-13-2009 | reply profile send pm notify |
I hate B/W |
b-alto | 04-13-2009 | reply profile send pm notify |
Click click click. Click right before it starts to back swing. I can put my old schwing on a gnat's ass.
Like Fred told me "don't worry in about six months you'll start to get the hang of it". |
mrmike36z | 04-13-2009 | reply profile send pm notify |
Practice, Practice, Practice...................................................Practice.
Snarf | 04-13-2009 | reply profile send pm notify |
Feather it. |
AK1 | 04-13-2009 | reply profile send pm notify |
ran a 32 putz before and old thompsons
all black and white
power on the function that is lifting normally worked for me and tap tap tap on the functions
going down
so power on for raising the main and tap tap tap
the function for down on the third section and almost always tap the turn |
Drew AUS | 04-13-2009 | reply profile send pm notify |
Tap tap tap Then Tap tap tap and when your finished tapping start Tap tap tapping again , takes practise, you can usually hold one stage and tap the other e.g Hold stage three up then start tapping stage one down fast, if you do big taps the machine will start rap dancing lol |
PUMBO | 04-13-2009 | reply profile send pm notify |
If its acting violently, you may need to troubleshhot the problem. Most manufacturers set up boom movements in harmony with one and other cylinders, so it is smooth operation. Best thing you can do is get into a habit of using two controls at the same time to distribute oil flow between two or more cylinders at any given time. Other technical options are, change or omit the orifice in the holding block to increase or decrease oil flow. If your boom cylinders have been in service there is a good chance the orifices may be mixed. In every case a cylinder extend slower than it retracts, thats where the orifices balance the movements. Turn the oil pressure down or adjust if at the pressure regulator if its too high or agressive boom movements i.e At max rpm adjust to max hydraulic pressure or lesser. approx 280 bar for long service life. Some black and white radios can be teleteached to change signal voltage to lower and can make operating slightly easier (in turtle mode opposed to rabbit mode). |
pudg | 04-14-2009 | reply profile send pm notify |
in my experiences you always tap the function that gravity is helping as boom down tip down and so on and hold the up function, on a putz the only way to slow it is to adjust your stack valves if youve been running a radio remote you will have to adjust stack cause they usually are wide open |
DaddyO | 04-14-2009 | reply profile send pm notify |
Get a big tube of ben gay you will be needing it. |
putzman19751975 | 04-14-2009 | reply profile send pm notify |
black & white and heavy 100 feet cord lol the good old days its all timing dont lean on it tap tap wait tap easy to hose wipt |
pumpinbear | 04-14-2009 | reply profile send pm notify |
TAP TAP TAP TAP TAP TAP TAPPERTY TAP TAP TAP TAP TAP TAP TAP TAPERTY TAP TAP GET IT HAHAHAHA |
toper | 04-14-2009 | reply profile send pm notify |
for u 30 sumthings, can u say '' STREET FIGHTER'' jk, definatly ,tap-tap-tap-tap................beep, pump off, beep,beep,pump on, tap-tap.tap............................... good times. |
TooTall | 04-15-2009 | reply profile send pm notify |
I would'nt suggest making any mech. adjustments just yet. It's gonna take some getting used to. Stay close to it for a while so you can see the whole boom and listen to what it's doing When you're practicing be sure to do it with the boom loaded. You can even load it with water in the yard to get a better feel for it while it's loaded. That much weight makes a huge difference in function. |
peewee | 04-15-2009 | reply profile send pm notify |
try checking your cord some get pulled and tugged around and things get loose not hitting plug in just right but if everything seems to be fine get a beat in your head your fav song (we will rock you always worked for me but i play drums) and it seems to make it easiers for me anyway plus the pump i used to run it clicked really loud and im i was self taught. GOOD LUCK |
Raymond | 04-15-2009 | reply profile send pm notify |
toper - Nice pull... Don't forget Asteroids. |
