CretePumper | 10-14-2007 | comment profile send pm notify |
wondering if any have had this problem, having an issue with accumulator dropping out usually 4 strokes and stalling out the S -Tube. This happens while pump is engaged ( forward or reverse) and retracting the boom, primarily while the Main and Jib are used, Extending the boom while pump is engaged everything works fine, seems this has baffled a few service guys, Any ideas on isolating this problem is greatly appreciated. The pump is a '04 40X 4 section R\F |
peter pumper | 10-14-2007 | reply profile send pm notify |
Put a gage on the hyd line and check to make sure accumalator is good. |
Tim | 10-15-2007 | reply profile send pm notify |
There is a list of things it could be. Give me a call if you would like to troubleshoot your Putz problem. Tim 303-762-0708 #124 |
