are there any downsides?
pumpon 09-30-2007
running airbags on a concrete boom pump ?
on jobsites?
pumpon 09-30-2007
do you think in a bogey situation a truck fitted with airbags instead of springs would be at a disadvantage?
pumpon 09-30-2007
bogey ,meaning muddy or bad traction
justanthrpumper 10-01-2007
Aren't all big booms, (52 and larger) on air ride suspensions? Ours are and I can tell you from expierience, our 52's are the best ride around.They drive like Cadillacs.
greedy 10-01-2007
 my 52 here in the uk has steel spring suspension the rear steer axel has super single tyres and air bags for ride and lifting when in pto
Mudslinger 10-01-2007
My old 52 had them on all three front axles,and I liked the ride,unless you hit the whoop-de-doos,then I felt like a ping-pong ball in a box!Because of the limiting cables!! Just cruising,she felt stable and soft!But boy ,let one blow,then that axle hit the stops,and you felt like you were driving a rock!!
Slavedattler 10-02-2007
We have a 42 Schwing twin steer with air bags. Lift the front end then make sure they line up when you bring her back to earth.
