Baton Rouge
bisley57 04-08-2018
 There is a certain home builder in Baton Rouge that builds roughly 3000 homes in south La and Mississippi that uses some of the some of the most unsafe work practices I have ever seen,Primarily nails not pulled from form lumber or roofing nails strewn all over the work area, Steel stakes for fencing are also seen protruding from the roadside ready to impale some passerby. Setting up a pump is always a challenge due to all the remnant building material in front of the slab.Here is my problem,if anything is said myself and the company I work for will be dropped and some other pump company will replace us on the job.I need some suggestions on how to solve this problem before some child becomes impaled on one of these objects>
orygun 04-08-2018
pay an attorney to request a job site meeting with osha. you bark but an attorney might bite.
bisley57 04-08-2018
In the real world,maybe        This is Louisiana       I did a lawyers office a few years back,and he had unsafe work conditions just as bad.    I believe that things will work out for the good ,one way or another, but I do appreciate your input Sir
