BLOWING A LINE WITH REMOTE CONTROL
Seed 02-09-2008
Does the remote have an air dump control? The reason I ask. The blow out cap appears to be a uni port with no air dump. I could be mistaken. Also do you always hold the line when blowing out? I like to stand clear. With being that close ( Safety Glasses ) You definitely look like you know what your doing! Thanks for the vid
Weave 02-09-2008
Is it possible suck a ball back with your pump? I was usually able pull back 200\' with rubber and steel.
hammah 02-09-2008
i usualy suck back as much as possible too if you know what your doing its fast, easy, and clean.
Bob 02-09-2008
My take on this is that.... if KAL came with the unit, and stayed with the purchaser untill such time as KAL\'s degree of professionalism was transfered to the purchaser every thing would be fine and good.
My problem with anyone that trys to make a fool proof system is that they do not have sufficent respect for the stupidity and ingenuity of fools.
Bob 02-09-2008
From a legal standpoint; I would suggest a professionally written disclaimer and to go with all the proper PPE. Remember... no good deed goes un-punished. ;~)
