| oly | 01-16-2012 | comment profile send pm notify |
Finished pour today brought boom back behind truck dropped hose everything is fine. While I'm folding boom to put away slew to left quits would go right but not left, had to swing with levers to get it to go left ? What do I look for its on a 47 meter putz. This is our first Putz pump any help guys. Thanks..
| Seed | 01-16-2012 | reply profile send pm notify |
Remote? |
| oly | 01-16-2012 | reply profile send pm notify |
Mechanic and I checked other functions they all worked. Checking in the main box with fuses and relays noticed it was receiving signal from remote I believe because the light would go on in there . |
| GARCIA | 01-16-2012 | reply profile send pm notify |
reset your remote with the cable, issue is not resolved then it's something hydrolics |
I will try that in the morning thanks .. |
| Travelteck | 01-16-2012 | reply profile send pm notify |
Try to swing the boom back right about 1/4 of the way and then back to the left. If you bumped the limit switch for left it will stop even though you might not be quite there, the switch might need tweeking. but before adjusting anyghing check with us there is a procedure and you dont want to adjust the wrong thing. Most of the time it is just a "soft trigger" and slewing away then back will fix it. |
| greedy | 01-17-2012 | reply profile send pm notify |
listen to what traveltec said limit switch on turntable happens quite alot on my 52 putz court me out when it was new |
| oly | 01-17-2012 | reply profile send pm notify |
Thanks Travelteck got it to work by doing what you said to do! |
