| mudcup | 03-23-2013 | comment profile send pm notify |
Yesterday sucked, pumped about 110yds of a 150yd wall moved the boom to other side of the wall hit pump forward heard a loud metallic bang. Lost all my hydraulics had nothing, cleaned out hopper,barrels,blew out boom with air had to disconnect hyd lines to move stube by hand. Everything got cleaned out even with 2% in the Crete. Anybody have any thought on what happened I'm thinking my PTO took a sh#t anybody had problems like this? |
| grass hopper | 03-23-2013 | reply profile send pm notify |
is that with perfects pump? i ran it for a little bit before you! |
| mudcup | 03-23-2013 | reply profile send pm notify |
Yes grass hopper, you the guy from VA? |
yea. that sucks glad you got everything clean |
| Mister_Perkins | 03-23-2013 | reply profile send pm notify |
sounds like your stabel box or hydraulic pumps took a crap. |
goes into gear driveshaft spins but nothing happening past PTO truck still set up on job in A frame |
Actually.. hold up. |
there are two air lines hooked on the front driverside RH side of the box. There is an aluminum plunger with a rubber o-ring connected on the box as well. This actuates the pump gear. With the truck off, try to move it one way or the other. If theres something broke in there you will either hear clanking, or it will be seized (Partially engaged). If it was partially engaged, it could have sheered off the shift fork. But you should be able to manually engage it to possibly get the pumps to engage, or if that fails, at least engage to get the truck driveable |
the Actuator shaft is usually held in place by a cover. They normally have 3 or 4 bolts. Once you remove the bolts and pop the cover off, it will expose the shaft assembly. Forgot to add that.
Hope that helps. |
Thanks dude I'm gonna go out to the job site Monday and see what I can do if anything to at least get it folded and drive it to Cole & Lambert in Maryland to get it fixed. If anybody else has any ideas I'd appreciate it thank you in advance |
| block | 03-24-2013 | reply profile send pm notify |
Yeah there pretty lucky a 46m happen to be cleaning out 5 mins down the street from the job site. Man that must have been a great company that came and rescued them after they bought there own pump and tried to take some customers from them. Hahahaha |
| mudcup | 03-24-2013 | reply profile send pm notify |
Yes block that company is terrific. Even the owner came out and made sure everything went well when that beautiful 46m pulled up to finish my job. They are a great group of guys. Glad to see the owner being the bigger person and not taking it out on the operator. |
| crazypumper | 03-25-2013 | reply profile send pm notify |
I Know The operator of the 46 meter that went for the rescue. He's a great guy and takes pride on his pump. |
| Mister_Perkins | 03-25-2013 | reply profile send pm notify |
Mudcup, what did you figure out buddy ? Find what the problem was ?? |
| mudcup | 03-25-2013 | reply profile send pm notify |
Horrible weather here today. I got a compayn coming out on thursday with me gonna make up the hyd lines and were gonna use our crane hydros to hook to the pump so I can fold her up |
why not just throw your winter coveralls on, some gloves, a face mask, and climb under the pump and pull that cover off. It will be really easy to tell what the problem is. You might not even need to hook anything up to the pumps if you can get that plunger to engage |
You ain't making $$$ if your pumps stuck on a job!! |
We're closed all this week and most of next anyway |
Well, good luck with the pump and hope you get it all figured out
You don't know all the issues the company that's gonna make up the hoses on can't be there till Thursday anyway and it's 2hrs from my house so if its not what you said it would be a wasted trip it has to go to cole & lambert anyway and the mech is in Wisconsin till mon of next week. Just don't be one of those guys that judge other operators. This is exactly why I don't post on here. Thanks for help though. |
I wasn't trying to judge you really. I should have just not posted anything because I just sounded like a dick and im sorry. I just know that if my pump was stuck on-location, no matter where it was or what day it was I would grab my truck / tools and go out to the job and try to remedy the problem (on my own time). heres a basic diagram:
Air supplied to one side of the PTO switch makes plunger move one way, PTO switch other direction reverses the air supply. |
| Schwing31ht | 05-22-2013 | reply profile send pm notify |
make sure you got 90 psi on your pto switch... sometime it's the air pressure regulator for pto switch |
