Cannot find a wire!!! grr
Mister_Perkins 06-22-2013
I am working on a 97 black/white Schwing 28 meter with Omnex remote and I'm trying to figure out where the wiring from light # 11 on the Radio receiver goes. Its connected to the vibrator switch, and light 11 illuminates and I tried to trace the wiring... Goes from the Uplink to the board, to the rear panel somewhere, then out the rear panel to the wiring box inside the rear cargo box. From there, I'm not sure where it goes to though. I cannot seem to get continuity on any of the wiring to connect me from that particular pin to the box itself. everything is labeled inside the box, but I am not getting continuity anywhere.
What I'm trying to do is switch the air cuff from the pump switch circuit to the vibrator circuit, because on the radio remote the vibrator circuit is currently not connected to anything. They have the pump switch connected to the vibrator, air cuff, and pump so what's happening is all that juice being pushed out is overloading the breaker and popping it.
If i could switch it to the Open switch on the remote (just have vib. and pump on a single switch) and the air cuff on the vibrator switch (changing the solenoid from a normally closed relay to a normally open relay) I think that it will stop tripping the relay so much. does anyone have any idea where I can find a wiring schematic for the 28 meter ?
gboom 06-22-2013
I Can send you a schematic, what's your email?
30something 06-25-2013
Why not install an additional relay for the cuff and one for the vibrator?
Mister_Perkins 06-25-2013
yeah i could do that, but I need to know what wires are what first! The crappy part is that there isn't that many switches on the Omnex remote, so your limited to what you can have as far as switches go
