GARCIA | 07-15-2011 | comment profile send pm notify |
is a small problem that can be a major problem, which is going to wear the ring of CIFA |
Dipstick | 07-16-2011 | reply profile send pm notify |
You could wonder if the company that does your mainenance has any idea what they are doing.. 5mm?? Sounds like you can't pump like that. But hey.. advantage is ... if you get your fingers between them you won't loose them.
pumper chuck | 07-19-2011 | reply profile send pm notify |
cifa cutting ring is a hole new ball game,all you have is two little spacer rings that might be 1cm together,the cutting ring is supposed to be a floater that should turn magically by it self as long as you keep it clean.ha what ever.when its starting to show wear its time to replace it. you cant turn it because it will go right back to where it was .so you dont have that option.one thing that might help is to buy a new one and hardface it before installing. it has helped with schwing and putzs before they started selling them already hardfaced. GOOD LUCK
