Con Forms Twin Cylinder Boom Tip Shut-Off Valve Now Available
ConForms 07-27-2015
The Twin Cylinder Boom Tip Shut-Off Valve is now available.
For more information about the valve or to place an order contact Con Forms sales at (800)223-3676.
Download the Product Sheet
Todd 07-27-2015
Very Very Nice Product.
PUMBO 07-29-2015
Looks good, what is the mass of the assembly fwc?
bisley57 07-29-2015
How would you know when the gate is closed? As a simple minded operator I cannot assume that this valve will never malfunction.     Use a proximity switch to activate a yellow caution light on the tip
Michael C 08-10-2015
The FWC weight is 76lbs with all hoses and valve for the tip shut off valve. The would equate to using a 9ft 5" tip hose instead of a 12ft 5" tip hose to keep within weight limits on most booms.
When this valve is open, you can see the plate is exposed so you will know it is open. It is very easy to see when the valve is open.
