| grass hopper | 12-06-2010 | comment profile send pm notify |
whats the best way to get concrete off of aluminum wheels? (with out acid) |
| Drew AUS | 12-07-2010 | reply profile send pm notify |
Theres a product called liquid hammer should do the trick |
| N.D.Fuccillo | 12-07-2010 | reply profile send pm notify |
You can put the pressure washer tip (hot water) right up to it and blast it off, sometimes it works really well, and other times it doesn't. I have also used a razor blade to poke at it carefully, NOT SCRAPE. Once you work at it for a bit, most of it comes off, and if you slip by mistake, then just polish the scratch and you will only know haha. I don't really mess with chemicals on wheels. |
| TooTall | 12-07-2010 | reply profile send pm notify |
I agree, HeaT removes concrete from anything that's aluminum. I managed to keep an original factory name brand sticker on my hopper shroud for almost 3 years! Because I never pressure washed the "inside", instead I'd crank up the heat and hold the pressure washer to the backside til it got hot enough that every splatter PoPped off like Popcorn (as the alum. expands from the heat) |
As far as chemicals go, MudSlide works awsome and is safe on aluminum And hardened chrome. Be sure to actually follow the directions or it does nothing. Its applied in 2 or 3 applications and without disturbing the unwanted crustyness between apps. just let it do its thing. |
| Telealbelt | 12-07-2010 | reply profile send pm notify |
Try Backset . It softens it and pressure washer will take it right off. |
| nzpump | 12-07-2010 | reply profile send pm notify |
Hey Tootall. Mudslide is a primer isn't it ? |
| The GOAT | 12-14-2010 | reply profile send pm notify |
The best product I've ever used for removing concrete is ZEP Mudslide. It will literally melt concrete off of any surface. It even can melt down latex mixes which always seemed impossible to clean. |
| mikey o | 12-18-2010 | reply profile send pm notify |
there is aluminum polish i use called busch supershine. it is pink and i can get it only at pilot truck stops.I can tell you it is the best. when you polish the rim it will soften the concrete up and bring any wheel to a sparkling shine the first time |
