| junhua | 11-29-2025 | comment profile send pm notify |
You may be interested in learning how concrete pumping can save your money. The ability to unload your material from the truck directly to its needed location can save you time and man hours. And fast pumping allows you to finish the job quicker thus saving you your hard-earned cash. The traditional method of pouring floors
and stems involved trying to back a mixing truck as close to the location as
possible. When the trucks could not get close enough, the material had to be moved
in wheelbarrows requiring a lot of extra time and effort. The mix also had to
be wet in order for it to flow down the chute. Sometimes ramps had to be built
in order to get the mix where it needed to go.
With the availability of pumps, the old
method may no longer be the most practical way to pour this mix. Now a hose can
be placed precisely where it is needed, and the mixture can forced through it
in much less time, requiring fewer men. Whether you are building a single storyresidence or a high rise building, you can get the material you need exactly at
its needed location.
This method of pouring allows the trucks to
remain safely away from the job site on the street and away from the holes and
clutter that are a necessary part of the construction. This means that trenches do
not have to be back filled and scaffolding or other equipment do not have to be
moved in order for the trucks to back up and unload. The results can be faster
unload times and the ability to empty one mixer then go directly to the next
one.
Another advantage of the pump is it can
deliver a drier mix.
Since the material is being pushed through the tube you can get the consistency
needed which can provide a stronger structure and faster drying time. You can
eliminate unproductive time spent waiting for the material to harden before it
can be finished.
These pumps are available for any job no
matter how small or how large it can be. They can be mounted on a small trailer
or a large boom truck depending on the application. They allow you not only to
place the concrete where it is needed but also control the speed of the flow.
You can determine the pace of the job and receive material where and when you
need it.
Now it does not matter what type of job you
are trying to accomplish. It could be a backyard patio or a one-hundred-story
office building. The fastest and the easiest way to obtain the mix you need is
by pumping it there.
You may want to try this quicker safer ethod now that you know how concrete pumping can save you money. Get the mix
you need and get it precisely where it is needed and get the job done in record
time. You may never want to go back to the old method of pouring again. More information,please visit JUNHUA
machinery, click here |
