| Travelteck | 01-13-2012 | comment profile send pm notify |
Someone was posting the other day about pumps tipping….. This got me thinking again …Oh http://www.cranestodaymagazine.com/story.asp?sectioncode=66&storycode=2037365 I got on line and googled cranes and outrigger cribbing I got this it is from 2006 but a good read never gets old take it for what it is. Lets discuss it. |
| concreteluvr | 01-13-2012 | reply profile send pm notify |
Awesome of you to take the time and do this on here. I hope people participate, listen and learn like the pros that you are. Pay attention. Never know what we can learn even with many years experience. Not a bashing session. This is a good opportunity for us all and a great person to listen to and share some knowledge and stuff with us. Need all you guys out there with professional input as Operators to share what you have. Thanks Travel. I believe this is the kind of thing this site was most meant for. |
| Todd | 01-13-2012 | reply profile send pm notify |
So whats the math look like again, i know you talked about this once before. |
| Travelteck | 01-13-2012 | reply profile send pm notify |
Dipstick please dont take this the wrong way it is about being safe. the size of the pad relates to the load. and you are right the contractor wont always know ,so the burdon is on you to understand the math. I was a line pump operator when I learned this and had never run a boom, but I learned a valuable principal, and it is a guy thing "go big or go home' If you passed the ACPA test you did this. The load on the end of a pump outrigger is a MAX posiable load plus a safety %. so if you build a pad of dunnage with this in mind you are building on the safer side not the lighter side. In the exapmle I show below I chose a basic 46000 lb load this varies from pump to pump as does the size of foot, so just plug in the numbers that fit your unit. I did not ever do the math on site as an operator, BUT I did know that a basic pad almost never was suficient to cary the load of the pumps I ran, I knew buy doing this exercise that if I built a bigger pad I drastically reduced the PSI exposed to the soil. I one time had a 42M sitting in a peat bog on 12 foot square pads I was literaly floating. so thats 20736 sq inches of plate and pad so if I had the 46000 lb unit in this Instance I would have had aprox 2.2 psi. I dont remember the load of the pump I was running at the time.
I did this a few years back on this site and goe -0- responces...... lets see what happens now, todd help me out can we offer something??? Outrigger load
46000 lbs This is found on the end of the outrigger on all pumps and varies with make and model it is just an example number. Buy the way soil AKA dirt can average from 12 to 75 psi and all over depending on conditions I am not a soils eng
If your foot is 8 in X 12 in = 96 sq in No Pad
Divide 46000 by 96 Sq in = 479 PSI Max load on Soil over you go.
outrigger pad 24 in X24 in = 576 sq in
Divide 46000 By 576 =79.86 PSI This is the load you would exert onto the soil.
Dont ask about a round foot that needs Pi and I am no math wizard
But look at this
Dunnage 6X6X36 in 5 pieces No 2x4's
this would be 36 X30 = 1080 Sq inches of Dunnage
Divide 46000 by 1080 sq in = 42.59 PSI
Look at the soil load diference Same outrigger
same max load
Same foot add Pad
Foot only 479 PSI
Foot and 2x2 pad 79.86 PSI
Foot Pad and Dunnage 42.59 PSI
Go big enough and you would float on water, thats how a boat works!!!!!
Simple math!!
All you have to know is how much your outrigger load is four your pump is.
And the size of your pad and dunnage, extra credit fro figuring out Pi
I would like to propose a test challange to the guys to see who can tell us the PSI they would put onto a 2x2 pad under their pump. Extra credit for a round foot
What do you think.
| Vasa | 01-13-2012 | reply profile send pm notify |
A round pad , R x R x Pi / load = load per sq2 or cm² (depends wich system You use , inch or metric , pound or kilo)
Dont all operators has to know that formula ? All pump and craneoperators must know that on the test to get the "pumplicens" or "cranelicens" in Sweden and i did the test for cranes more than 22 years back and pump 18 year.... |
I dont know the maximum pressuer sq2 in pound but in Sweden it is 5kg / cm² . And I think You mean 2 x 2 feet ? Thats 60 cm x 60 cm = 3600 cm² x 5kg = 18 000 kg or 18 ton I have 27 ton on My outriggers....
My round pads are 120 cm diameter .
60 x 60 x 3.14 = 11304 cm²
27 000 kg / 11304 cm² = 2.39 kg/cm² |
Thank youyou have it and yes it is 2 feet square we use feet and inches converting back and forward confuese us all.
thank you for adding |
If my conversion programe is corect 5 kg/cm2 =71.11 PSI |
| Vasa | 01-14-2012 | reply profile send pm notify |
On big buildingplaces they have done a geo investigation , how much piling and typ of piling they have to do .
Tell the super that You want to see that .
And test it with a ironrod Yourself .
We have them sign a contract if they dont can say how much the groundpressuer is and if an accident happends it is the builders responsibillity .
But if You stand on steelplates or cranematts the pump can go over... If it is something hidden in the ground or a waterpipe breaks or groundwater rise quikly... I have seen cranes and pumps go over that has stand on several m2 of steelplates and Wood . They have stand for many days and suddenly the ground breaks , I think every country or Towns has areas that has terrible groundcondition , many of the member here on the site that always says it is the operators fault operates in perfekt conditions . When a 2'x2' pad is enough under the suportlegs . |
Dipstick I was not thinking of You , You are from Holland but live and work in Norway ? And the groundcondition is not so good in Holland ? And I think that some parts of Norway and Sweden has the same groundcondition with much mud and water.... |
| SUPERDOFFER | 01-14-2012 | reply profile send pm notify |
Vasa you mean something like this cranemats 2.5 by 1 meter
This operator made one mistake. if you don't put your rigger in the middel you have only half the cribbing |
| Travelteck | 01-14-2012 | reply profile send pm notify |
This is a very good post and THANK you all for contributing, Just getting the point of the math is a huge part of the battle that saves damage and lives. Do you know what in under the foot? is the dirt good, Plumbing, this is a BIG boom 58+ it there any excuse that this would EVER be legal! Sad part of things like this is the guy had large timber ON the unit and didnt use it! I have to ask is it lazy, Ignorant or poor training all 3 can be fixed. Thank You again and Yes I am passionate about this. There is no shame in going BIG it should be not just the theme for our "booms" |
| northwest63 | 01-15-2012 | reply profile send pm notify |
moor is better. |
here in the N/W. I never trust the ground under ANY pump |
to maney people are under our boom's |
Their is no such thing as over kill. |
| Travelteck | 01-15-2012 | reply profile send pm notify |
Thats a big AMEN NW 63 Thanks for the pics and support. I always looked at it like this When I went BIG and did my best then IF something I couldnt know or controle under ground happened, at least I knew I didnt go lazy or cheet. then it would be an accident.
I had a real eye opener in Japan. We were in the PMJ facility a Paved yard with Steel plates and Large wood blocks under the 70M Training. we experianced an earthquake with the boom open and for the first time in my life I watched a pump dance on its dunnage and the unit wansnt stroking, the quake was short and mild but a 70M sliding around on dunnage squeaking and the boom swinging around was an earie feeling. I looked down to the plates and pads and was confident we had done our best but some times we cant controle it all. Guys thanks for doing your best. GO BIG. |
| mile mark 96 | 01-15-2012 | reply profile send pm notify |
I think in the last picture you would have been better off using your pad and the crane mats,too much air in that steel box... |
| SUPERDOFFER | 01-15-2012 | reply profile send pm notify |
mile mark 96 how much air do you think there is in a outriggerbox. I am not an engeneer but the steel looks good to me to spread the lood over multiple cranemats. |
And why using cranemats on a concrete slab.
because concrete can be a bad thing to set up a pump. |
look ma,I built a pump out of macoroni.....eeehh |
not open in the middle...they are not just H-Beam's |
not just on long boom's even on our 17mtr.... |
| Many | 01-15-2012 | reply profile send pm notify |
common sense,if it looks like a gater,it's probably a gator. |
| Z-Boom_Parks | 01-16-2012 | reply profile send pm notify |
Just a quick side note on cribbage and looking at NW photo with the steel beams, but I was always shown and instructed to place cribbage whenever possible so it's in line with the O\R. Just in case the pump ever walked a little. |
| Granddad | 01-16-2012 | reply profile send pm notify |
This formula isn't just for operators. Any person involved with pumps or cranes should know this. In an era of lawsuits and backcharges any information that helps should not be discounted. I challenge anybody to go to a super and ask for bigger cribbing because you feel like you need more. You will feel something alright. If you ask for bigger cribbing based on a solid number of what is needed to support you there will probably still be an argument but you have something to fall back on that is supported both by the pump and crane industry. And if there is an accident no one gives a f@#& about your feeling, they will want to no exactly how you decided what size of cribbing was to be used. Owners/operators/dispatchers and salesmen learn this!! Use it!! This is one small thing that we should all be able to agree upon as an industry to make us all smarter and safer Hallelujah Holy Shit Wheres the tylenol |
| northwest63 | 01-16-2012 | reply profile send pm notify |
under the feet on my tb130 |
| boony | 01-16-2012 | reply profile send pm notify |
how about an iphone app toddy to simplify things.and someone made a good point about how do you know what the ground pressure is.im pretty sure i saw a decal on a pump saying not to set up on virgen ground any takers? |
| Travelteck | 01-17-2012 | reply profile send pm notify |
Remember the point is if the soil is soft the pad is BIG A big ship floats "most of the time" so can a pump You can sit on soft soil with the corect square inches of sutiable dunnage under the outriggers for the size of your pump hear is a test for you You have a Peet Bog to set up in your left Frount outrigger will need to sit in the bog. Max load on the outrigger is 46,000 Lbs Site Eng tells you the bog will support 2.5 PSI How big do you need the pad/plate to be to be safe. Can you do it Safe? This is a good test for Owners / Sales/ Dispatch/ and operators PS all 3 other outriggers are on 12 inch thick stable concrete, Factory pad is ok. |
| SUPERDOFFER | 01-17-2012 | reply profile send pm notify |
1.2 squared mter wil do if my caculating from impirial to metric is right. |
excuse me if I am wrong but 46.000 lbs make 20865KG and 2.5psi is 1757.6KG square meter Oeps dipstick You are right I just tipt my pump just one,,,, wrong |
But I believe that my experience in the swamps had saved my as. The pic of the 52 is in that kind of circumstances. When in doubt call in the cranemats. |
I Love this I can almost smell the brain cells smoking, Guys I am impressed, Dont forget the number on the outrigger is Outrigger max load, full stick over leg plus a safety margine. you dont get into this range if you dont overload your boom , so building Big based on this math is adding a safe margine. Please keep up the dialog. this is gold. |
| Dont need one | 01-17-2012 | reply profile send pm notify |
His pads are fine under these conditions. |
Set up on concrete slab, trying to keep from brakeing it. |
Overkill on the rear. |
Looks like somebody knows there is some sort of ground issue, or overkill. |
Looked like water in front of the pump, or set on a pier. |
Definetly bad ground, looks like moister in the dirt. |
17 meter had to do that to level up, but not built right. Should have been a little wider on bottom. still worked but pryamid style a little better. |
You guys wanted to whine about the green pump having extra dunnage on the side look whats on the ground just below this outrigger. |
I was replying in order of all of the last pictures in order. and no I dont know him. I just dont like people who dont know what they are talking about. I have been running pumps for 33 years, everything from a 23M to a 61M, everything from a 1 story building to a 45 story building and never dumped one. Oh by the way I will be at WOC. Stop by and congradulate me. |
They were not all in order. Northwest 63 was setup on the concrete they did not want to brake. |
Dear dipshit I didnt say I cant learn anything else, I am only 54 years old. Ididnt know the green guy. But if you want to learn a lot more come to Colorado and I,ll help you. I have worked for the biggest company and best company in Southern California MERLI and the best company here. So stop on by some timejunior and we will see. |
| Travelteck | 01-18-2012 | reply profile send pm notify |
One thing we all need to remember is the day we stop learning is the day to hang it up. When I left daily pumping to work for Puts I thought I was king of the sport and I was pretty good, but as I kept learning I found out a lot of things. And every day I learn more. One key thing I learned was I had been trained by the old timers that had been trained by guys that trained themselves on the, beat you head against it method. Documentation was Nonexistent, and face it, most of the pumps had different kind of manuals in the rig……. If you get my drift. During a ride along I would learn about the guys 4x4 or girl friend or the one he hates now oh and buy the way don’t get close to the power lines, and put out the pads…. A lot of didn’t get QUALITY training. But we made it work. After an accident happens then all the questions come out like did you do ???????? Can you do ?????? Where did you learn this?????? As I have evolved with Putz I have just continued to grow and learn, every day it is something new, and I love to share it with every one I can. It is a wonderful feeling when a 25 year veteran quietly comes up to me after a school and thanks me for explaining the math or describing the reason for the bigger outrigger pads, because his old man just did it that way so that’s how its done. My goal here is to grow the industry towards a safer place and if only 1 guy makes the trip and moves up it is a win, I think a lot more are responding than 1. There are literally Thousands of variables to every day and every pour, with knowledge we can approach each one of them new and safer than the last. I will be at the show in Vegas and would Love to see any one of you that attend Be safe and of course I will see you in the field . TT |
| Many | 01-18-2012 | reply profile send pm notify |
how true those words are |
| Beast | 01-18-2012 | reply profile send pm notify |
Dear Do Need Attitude adjustment, Are you here to complain or just downgrade folks ? If you and your infinite wisdom are so great , why not share it, instead of running your mouth so reckless ? These guys are learning something and you choose to talk shit, to say your 54, have you learned to spread your so-called wealth of knowledge ? or do you just ridicule and chastize ? One question , How many ass whoopins have you taken in your 54 years ? just asking , invite me to come see you at WOC, nothing better than a little ass whoopin in Vegas and maybe you'll be the one doing the congratulating. |
| Todd | 01-18-2012 | reply profile send pm notify |
Ok, come on guys, we are all family here, lets not forget that. Yes brothers love to fight but lets keep it clean ok. We are all on the same side here. |
| concreteluvr | 01-18-2012 | reply profile send pm notify |
Yea Beast. This is the guy who should be deleted alright. |
| SUPERDOFFER | 01-18-2012 | reply profile send pm notify |
Dont need one This is overkill and it was on boulder clay if you know what that is. |
Over kill is never a problem reall is it? |
| northwest63 | 01-18-2012 | reply profile send pm notify |
just my 2 cent's on the 17mter pic.the lower stack is bigger than the outrigger pad...it is done wright! just saying |
Great stuff. Great input. DO not let one unhappy person wreck the good stuff. |
Amen Guys thanks for keeping this positive, this is the point to growing safety. everyone has opinions and open forum's bring them all out. no one is perfect and not ONE of us can say we have never pushed a limit, but accidents happen and continue to happen when ignorance prevails. I must say Todd this post will be one of the topics of the show, glad to see it. I am sure glad we are not talking Polotics on this forum!!!!!! |
| Beast | 01-20-2012 | reply profile send pm notify |
Treveltek, thanks for the great info, sorry I had to get a little bent , but seemed as though no one else was gonna say something to shut this guy up, keep up with these informative posts they are great training tools. |
| ALMIMA | 01-20-2012 | reply profile send pm notify |
"Vasa" I like your knowledge how to calculate the groundpreassure on a full outrigg - ideed i´m impressed! I run a linepumpcompany and as license-Sweden we live in.....i was forced to have the same pumplecense as you have, only because to run a pumpcompany at all - the government didn´t understand the different that my company is a linepumpingcompany - NO OUTRIGGER. No cheapmoney to get the license!!! But i can tell you that you know much more than me about calculating groundpresuring around a full outrigged pump - i know nothing about that and i really dont care - but i have the license...the same as you have hehe. That license do not work so well to show of in a coctailbar.....Not even my wife was impressed of that license (2 expencive handbags and 3 pair of very fancy shoes less, did my concretepumplicense costs her) And i don´t know what use i have to got that license - just because to be a leagal lineconcretepump-companyowner in Sweden. |
