Ti-so | 02-11-2015 | comment profile send pm notify |
Hello i used to have an old version of a roughneck 5-3 hose. The last 6-8 inches was super Soft so i could fold it and attached it . But after 4 years of abusing it the soft end rip .I order a new one but now the end all wire bread till the end so there no way i could fold it to reduce mess . what are you working with?any suggestion ? Marc |
Dipstick | 02-11-2015 | reply profile send pm notify |
Maybe a mud-snake? Lay flat hose? I would want to have a normal 5'' endhose without steel and a pin-pour in it. A good air clamp and get used to it. At the end you will not make a mess anymore.. |
Ti-so | 02-11-2015 | reply profile send pm notify |
does a mud snake has tendecie to bent when to hosemen push to far ???Could you lay it down when you are flat boom?
should buy a air shut off?witch one??How much a complet kit could represent?
any other suggestions before investing 10 000$? |
Joe | 02-11-2015 | reply profile send pm notify |
mudsnake not good for everyday use and cant push if short in corners |
Should clarify on big pours with lots of volume |
What do you use then?? |
Don't get me wrong.. I would not go for the mud snake. I just thought it fitted most of you wishes. I think some of the newest best mudsnakes don't kink so easy. You can lay them down and pump I believe. |
and when you need to put on system ist easyer to take off then a heavy rubber hose. |
ericICF | 02-15-2015 | reply profile send pm notify |
Marc is your 5 to 3 a Conforms Ruff Neck or a copy ? We just got a Ruff Neck and its good . I have seen a knock-off copy full of wire braid and its no good at all. No flexibility . |
Conforms products may be more money , but they are superior in every way. |
Ti-so | 02-16-2015 | reply profile send pm notify |
I bought it from alliance it s a conform it cost 1600-1700 $.but i wrote to conform and they inform me that don t carry the version i had for safety issues. But are telling me that you can fold yours?
schwinger_swinger | 02-17-2015 | reply profile send pm notify |
Been using the 5-4 really liking that one from conforms |
Beast | 02-26-2015 | reply profile send pm notify |
Guys , maybe the mixes where you are at are different , but fair warning with those 5-4 reduction hoses , they can turn a day real sour quick. Keep your reductions in steel. |
naptowndaddy | 03-26-2015 | reply profile send pm notify |
Ti so Don't lay those babies down, and yes they kink at low volumes easily however if you inform hoseman beforehand and pay attention they are a great product. Little to no splatter even at trickle.
Devin | 03-27-2015 | reply profile send pm notify |
Ive got a putz brand 5-3 hose that works amazing for me on wall and footing pumps. Unless a mixer sends a fin i have no problems. if they do i just switch over to a 5-4 steel with a 4" tip. Which is my normal setup for a floor or a big mat pour. other than that the putz 5-3 is my everyday hose and i love it. |
Farmboy72 | 03-27-2015 | reply profile send pm notify |
As long as your paying attention, and DO NOT Rush it, the 5-3/ or 4's work great. If you don' t rush you have more time to react when there is a problem(chunks or dough balls). It also helps to have an extra grate across the hopper to help catch any possible problem pieces. |
