Seed | 06-28-2007 | comment profile send pm notify |
I need two cooling fans on a 98 Putz. Should I dump the $180 a piece for the replacement fans and keep it quick and simple. Should I try to be creative and refit a fan from Nappa for $30 bucks each? |
mrmike36z | 06-28-2007 | reply profile send pm notify |
Hydro cooling fans not engine right??
Seed | 06-28-2007 | reply profile send pm notify |
Yes. |
Bob | 06-29-2007 | reply profile send pm notify |
Check with the Korean mf'g first. Then make a decision. Check the "pitch" of the fan blades too. Less pitch, less air flow. I know that the Korean machines are return to tank not closed loop, but they sure know how to keep the oil cool. |
Seed | 07-01-2007 | reply profile send pm notify |
Thanks Bob, I checked and was quoted at $600. I almost fell off my chair. With a price like that $180 was a deal. So I just ordered a replacement from my vendor. |
Bob | 07-01-2007 | reply profile send pm notify |
Man, that is WAY too much too much too much. What a rip. Who gave you that bogus quote? That price must have been for a hydraulic motor and fan and shroud and heat exchanger.....WOW!!! |
I don't want to name any names. I called two of them and the other guy needed the numbers. I liked the way it worked out. I called my vendor and told him I needed a fan for my cooling tower on my 98 Putz. They are all the same so it was an easy part. He sent it out. My guys are quick to get my stuff out. That makes a big difference |
Bob | 07-02-2007 | reply profile send pm notify |
service sells |
Tim | 07-02-2007 | reply profile send pm notify |
Here is the information you are looking for it is an alternative to the typical high cost parts you are accustomed to. Ryan Siedel Ph, 800-345-0327 Fax 800-654-7725 /12 volt fans part # 2042 SPAL
Tim, Can you post a link?
