crete | 09-28-2015 | comment profile send pm notify |
Running 3" hose/pipe on a trailer pump. Procedure for washing out is as follows. Disconnect hose from pump.clean out the hopper cylinders etc.Insert a ball into the hose and use the pump to clean out hose. Brand new cutting ring and wear plate. Seems lately water is pushing past the sponge and rock packing the system so I have to break down hoses and rinse one at a time. Ive never wrapped the sponge in a plastic baggie. going to try that later this wk. Usually doing this with 150' or so of hose. Do you think I don't think I'm trying to clean to much system am I? Any ideas? Terry |
greenguy | 09-28-2015 | reply profile send pm notify |
Try a harder sponge ball. If that doesn't work, use a soft sponge That's 1" bigger than the line size you are using. you also might want to check that your sponge supplier didn't recently change vendors. Not all sponges of a given size and firmness are created equal. You might just have a cheap/bad batch. |
TooTall | 09-28-2015 | reply profile send pm notify |
Sounds like whatever you're using for a sponge is open cell sponge material. A good rule of thumb... If you can blow air through a sponge, It's only good for washing your wheels. When I'm looking for a good sponge (rabit/pig) I actually hold it to my mouth and blow. Single cell sponge material doesn't allow air to pass through it. Or water for that matter. Schwing balls are best but expensive and can't be bought at Fred Meyer. NERF footballs work great because they are single cell material. In a bind, a good wad of news paper soaked in water and rolled to fit snug into whatever size system your blowing out works good. Snug meaning you should have to use your thumbs to push it into the end, then use your hammer handle to push the paper wad far enough in to put your sponge behind it. This way if any water passes through or past your sponge, it won't separate and rock off your system. |
A lot of sponge balls have a rubber coating on the outside that wears off over time allowing water and air to pass through and ruin your day. |
There's a number of commercial pipe pigging suppliers online. pipepigging.com has a good variety of affordable products. |
Dipstick | 09-29-2015 | reply profile send pm notify |
For as far as I can see you have just been lucky that it worked before. Cleanout with water works great but you need the right ball or plugg to do it. Just a soft ball with a plastick bag might not be enough. And for the guys that just fill the hopper with water and wash out without a ball I would really like to see that some time. Seems like a recipe for a big mess to me. One thing I have learned in my years as a pumper is : don't believe operators that say they ''NEVER'' have a problem or ''WORKS EVERY TIME'' Their customers tell me different stories |
I don't get it. When I try that i am garanteed to end up with a line full of rock and water and one big disaster. The water washes out and seperates the concrete. Even with several balls and a plastick bag round them nothing helps. Ok the first 20 meters maybe but no further.. What does work is go-devils in steal line. We push out over 500meters of line that way without any problems but we really need good tight go-devils. What is it that makes it work for you and not for us? The concrete? We mostly have very high slump concrete with lots of chemicals and little water.. What is the longest line you have ever done without any ball? Is there any rocks left in the hoses afterwards? |
Beast | 09-29-2015 | reply profile send pm notify |
I only water wash line pumps if I am using a pea gravel mix with small line and I always push a hopper full of water first then insert a sponge |
BCCP | 09-29-2015 | reply profile send pm notify |
Doesn't anybody use air? I just blow the hoses back into the hopper with any kind of sponge. Unless it's a really shitty mix it works everytime and the hoses are clean enough to put away with no water. I do spray the ends off with water and the first hose off the pump usually needs to be sprayed out a little bit. 300' is the most I've done this way. |
crete | 09-30-2015 | reply profile send pm notify |
I guess my first step is going to buy a new hard ball and wrap it in a baggie. I've got a wheelbarrow type compressor (hoping that will be enough air) All of the proper connections came with the pump as far as a ball catcher and air connection with a relief valve,might even give that a try. I would try washing water with out a sponge,but it seems like a disaster waiting to happen. I've alaways pump the sponge though on full throttle at the highest strokes per min. is this correct? Terry |
ericICF | 09-30-2015 | reply profile send pm notify |
Newsprint works.Ball it up as hard as you want. If it plugs in there, it wil soon deteriorate, so its not a problem. |
Beast | 10-01-2015 | reply profile send pm notify |
water wash will work on booms , but when I have done it with regular rock on linepumps 4" line , I always get rock jammed ,water washing booms is totally different because you have gravity , 2.5" line and pea gravel 25 years and I have never had one issue , and like sandstar said a quick roll and dump usually gets you clean as a whistle. |
crete | 10-02-2015 | reply profile send pm notify |
Well.. Experimented a little bit yesterday. I had 1 25' lenght of hose off the pump 100' of pipe and then 50' of hose. Used a wheelbarrow type compressor with a wet paper wad and a sponge behind that. It started to move but then stopped,it would move if we kept beating of the last length of hose. I relieved the pressure and got it to clean out the first hose and pipe. It didn't come out with the explossive blast I would it would. Just a small pop. I think I'm on the right path if I want to air clean out. I'm thinking my smaller compressor doesn't have enough volume the keep the sponge moving as it would then stop and then move again. For safety sake I did use a ball catcher on the last hose. I think I may be on the right path if I want to try air again what do you think? Terry
sherpa | 10-02-2015 | reply profile send pm notify |
Terry if you inexperienced with air blowout id advise you to be EXTREMELY careful while doing this. There are many measures you can make to do this alot safer as peoples life's are at risk with an air blowout. I know how the American pumpers feel about air and i agree if precautions aren't taken air is very very dangerous, unfortunately in Australia water wash isn't really allowed so it has to be air alot of the time. So a few things to keep in mind, you must be either in radio phone or talking contact the entire time with the man on the valves the man on the end of the rubber and the man following the line checking where the ball is. Probably the best way to do it is to blow nearly until the end of the line, say 15-30 feet back and dump the pressure empty the last bit of hose by hand then reconnect and blow the ball out of the last section of rubber that is already empty. If you can a remote setup is also ideal (as long as it has an automatic air release on loss if signal) but i know not many people have this. Never blow a ball directly into the concrete itself as this can cause it to explode concrete everywhere, never point the hose up to blow upwards this is just crazy, use a wheel barrow to blow against and keep the hose in a straight line behind the person on the hose so it doesn't whip. Always dump pressure as the ball nears the end of the hose NEVER just leave the line pressurized and allow it to blow out. Of course linesman should be wearing PPE. Be careful this is EXTREMELY dangerous if done wrong |
Dipstick | 10-02-2015 | reply profile send pm notify |
What you had sounds like worst case senarion for risking a big accident. Bal stuck at the end. Very wise to not keep the pressure on and try to beat the ball out. Even if its only 5 or 8 bar you will push a hell of a lot of air in that hose and all that air wants to come out when the ball reaches the end. Maybe you had a to big ball? Don't overdo it with that. Use the right size ball and no hard balls.. On such short lines it should work with a smal compressor also.. I always push until the ball reaches 2/3rd of the distance and then stop the compressor and wait untill the flow almost stop. Than push a bit again and stop again. Repeat untll the ball comes out.. |
b-alto | 10-03-2015 | reply profile send pm notify |
Terry i haven't even considerd using water since the first time a blew with air. Are you using a large air hose? it needs to be a 3/8" ID minimum. I've never not hand enough air pressure. Also have a dump valve and keep letting the pressure off. 3 inch hose doesn't explode like the smaller hoses do. Be careful with 2" and 2.5" it shoots hard but i blow out every time. Buy 3 " poof nerf balls they work best. I blow one through then dump five gallons water in and blow another ball. Fun and easy : ) |
ericICF | 10-04-2015 | reply profile send pm notify |
Terry you are on the right path, and the guys here are giving sound advice ! Your compressor is around 5 cfm at 120 psi, and that is lots of air for 3 inch line. Remember compressed air is like a coiled spring, the more air you deliver to your system the greater the re-action in the hose. If the ball stops..that means the resistance is greater and it will take more air at higher pressure for action to occur. Action equals re-action. More pressure is required for rubber than for steel. More preseure is required for lower slump as the friction resistance is higher. Give yourself a better chance by wetting down the last few hopper fulls if you can. And try to find the video of Calvin Coates on youtube doing it Aussi style. Those guys have small line air cleanouts dialed. |
crete | 10-04-2015 | reply profile send pm notify |
Hi Eric and Brian, Do you think I'm trying much much lenght of system at this time? Also to move to 3'8" fittings they much be the pressure washer style? |
sherpa | 10-04-2015 | reply profile send pm notify |
Terry i have blown air through lines as long as 400 feet (with a small petrol 5.5 hp air compressor), the longer the line the more air volume and more pressure, so when releasing you need to dump air alot earlier to drop the same amount of pressure. I use a 1/2 inch air line to my blow out cap and a 1 inch release valve (the bigger the release valve the better as to drop pressure faster) |
b-alto | 10-04-2015 | reply profile send pm notify |
3/8 ID or 1/2 inch ID im not sure what mine is but large like you have to use for an impact wrench. I usually pump the hopper empty and push as much concrete out as possible. Then hook up my blow out cap and crank the air once the mud starts moving release the pressure use just enough to move the mud, when you think its getting ready for the ball to come out release the pressure. Practice by putting the hose out in a cleared area. 3 inch is easy. I have had the smaller hoses blow the little foot ball 100 yards out in a lake.. |
To Brian how long of a push have you did? I would buy some 1/2" hose I believe the quick connects for this would be 3/8'? Do you think a 5.5 hp makes enough volume for me to try? |
I have pushed a couple hundred and still would. But once a blew 200ft of 2.5" and i couldn't see the end of the hose so i turned it on ran down and held the end hose. BLAMM.. shot it out of my hands and made a mess, don't do that. Its good to see the end and try to relieve the pressure when it speeds up. Its not a bad idea to only push under 150 feet. Yes 3/8" coupler and 1/2 hose makes all the difference, and a good wet ball. And yeah all i use is a wheel barrow type like you have. |
Alright then going to give another try next week. FWIW I did use a nerf ball from Walmart wrapped in a baggie, maybe try it with out the baggie this time. |
crete | 10-14-2015 | reply profile send pm notify |
Welll! I might be on to something. I little bit bigger air line and fittings were maybe all I needed. Had 50' of hose and 100' of pipe and pushed it clean with no problems. Not even a big explosion and the end, ball just popped out maybe 10' at the most. Used a nerf ball wrapped in a plastic bag the first time, then a sloppy wet sponge the 2nd time at things are clean as a whistle. Woo Hooo!! |
b-alto | 10-14-2015 | reply profile send pm notify |
Glad to hear it! Today i blew out a 125' of 2" i used a racket ball that just fits in the hose. Then i stood on the hose and ran suficent air. It poped out and flew about 100 feet. |
DIGGER | 10-14-2015 | reply profile send pm notify |
We have been selling remote controlled air blow out kits. Just about ever pump sold now orders the radio remote blow out. You are at the end of the hose, letting air in and controlling the outlet speed. Once used to it the ball just drops in to your hand. |
sherpa | 10-15-2015 | reply profile send pm notify |
Digger, where do you buy these remote setups from? I really want one , I was going to make my own (with the help of an electronics guy) but if there is an off the shelf solution that's not too pricy I would opt for that |
ericICF | 10-15-2015 | reply profile send pm notify |
Sherpa : Digger is the owner/ manufacturer/engineer of Trancrete Concrete Pumps amd one of the early developers of the S-tube. We are very lucky to have his input and experience replyimg on this board. I didn't know his blow-out kits were available in North America , but I have seen them operate and they are fantastic.
sherpa | 10-16-2015 | reply profile send pm notify |
EricICF: ah didn't know digger was Ian hay, feel.a little silly now. Well Ian I'll have to give you a call. We met briefly once when I brought this unit Round and you tested the hydraulic cartridge for me and helped me out on short notice ( thanks again). |
crete | 10-16-2015 | reply profile send pm notify |
WOW! This is really the world wide web. |
