Craziness on job today
Mister_Perkins 10-22-2012
I was pumping grout up to the 4th floor of a building today, and they had me setup next to a crane.
t
apparently with this crew, Riding the crane is normal
Its probably OK footing, but i dont like having spaces between my cribbing
tws
Goose2448 10-22-2012
That seems kinda unsafe in many ways.  I hate cranes, always getting in my way, and of course they get the prime spots.  They couldnt have hired a line pump to pump grout?  And it looks way thick.  They grouting by hand?
pumpslut 10-22-2012
small spaces on thick timber like that = no problem at all. can help make the area bigger = spread the weight more.
Boomerr 10-22-2012
I run the same pump its an old pumpcrete pump from Toronto.  Its old reliable.
Mister_Perkins 10-23-2012
goose, they were flling cracks in the concrete panels so they requested a pump. probably could have been done with a trailer, but for some reason they prefer using a pump.
and boomer, do you work at pumpcrete too??
and they wanted it at that slump because they said it filled in better. what they are doing is dropping a pile onto the ground then they use squeegys and spread the grout in between the pre cast panels so they are flush
