mothy | 11-13-2009 | comment profile send pm notify |
WE HAVE A 1998 42 METER PUTZ I WAS OPERATING IT LAST FRIDAY AND THE CROSSOVER POPPED OFF THE FRONT PUMP AND ALMOST OFF THE BACK ANNY SUGGESTIONS WOULD HELP GOT THE HOSES BACK ON IN TEN MINUTES AND AND SAVED THE POOR BUT IT POPPED OF FOR A REASON ? |
pumpit | 11-13-2009 | reply profile send pm notify |
describe crossover |
mothy | 11-14-2009 | reply profile send pm notify |
THE 2 INCH HYDRALIC CROSS OVER HOSE COMEING OFF THE MAIN PUMP IT ABOUT A FOOT 1 1/2 FOOT LONG |
Justapumper | 11-14-2009 | reply profile send pm notify |
Well it could have popped off because it was loose enough. I check all of my fitting and, clamps when I do regular maintenance. I have found clamps that have just loosened over the years. |
TooTall | 11-14-2009 | reply profile send pm notify |
Those short fat ones are fun to wrestle, they dont like bending much! I'm guessing it was a bolt on type fitting if it 'popped' off. Inspect the metal flange on the hose end, both sides, be sure the edges are not rounded or worn. Also inspect the bolt on collars for signs of wear. Maybe compare it with a new one or one that's working properly to see if it's worn or possibly even bent or tweaked. If it's a compression fitting that's pretty crazy. I coundn't imagine one just coming off without a ten foot cloud of hyd. oil before hand. |
Gdoubleg | 11-14-2009 | reply profile send pm notify |
If the pumps are Sunstrand check for brass in the hydraulic oil. Probably time to upgrade to Rexroth.
mothy | 11-15-2009 | reply profile send pm notify |
no there had to be a surge because i had to really loosen the hose clamps to get it back on they didnt just slip off the front part of the hose found its way threw to big hyd lines i had a hard time getting it threw them to put the hose back on |
bisley57 | 11-15-2009 | reply profile send pm notify |
suction hose.......... |
Gdoubleg | 11-15-2009 | reply profile send pm notify |
Case drain line between both pumps blew off. Pumps starting to come apart internally. This is the reason Putz changed to Rexroth. Many pumps replaced over the years |
