| pumpon | 07-01-2007 | comment profile send pm notify |
what are peoples opinons of using a cube sponge instead the balls at the moment we are using round balls from conforms for $25 but i can get cube sponges from quick prime for $6 never tried a cube , will it work? |
| Bob | 07-01-2007 | reply profile send pm notify |
They work like a charm. |
| pumper chuck | 07-01-2007 | reply profile send pm notify |
I'm with Bob on that.One of these days,(not to knock any sponser)they are going to realise the price of there BALL'S is to high.A rejected nurf ,come on. |
| Seed | 07-01-2007 | reply profile send pm notify |
I like the Med 5 " balls from Pumpco for $13 each. |
| MidnightRider | 07-01-2007 | reply profile send pm notify |
i use those old elcheapo square sponges, they work wonderfully dont know what they are cost wise to the balls but i will find out, and yes you can blow out system with them because i have done it. |
| concrete animal | 07-01-2007 | reply profile send pm notify |
I SWING THRU TOYS-R-US ONCE IN A WHILE AND GO THRU THE BINS OF BALLS. SOMETIMES THE RIGHT SIZE FOAM BALLS ARE THERE. WHEN THEY ARE I STOCK UP FOR ABOUT 4 OR 5 DOLLARS A PIECE. |
| Bob | 07-03-2007 | reply profile send pm notify |
When I worked for PumpcoParts we used to buy these "Champion" brand balls. They used to be cheaper (what did not). They have coated and uncoated. The coated ones lasted longer, but the uncoated ones were easier to use, cheaper, and if you washed them after use they would last pretty well. I have been to 999 websites trying to find the cheapest price on these and this is the best price I could come up with............ INFLATION!!! http://www.shoplet.com/office/db/CSIRD7.html# ;~) |
| Mudslinger | 07-03-2007 | reply profile send pm notify |
Hey Midnite: Why dont you tell them why you really like those square sponges? Cause they make really great pillows when you're sleeping under a tree somewhere,hiding from dispatch!! HMMMM??? |
