did someone mention dunnage
The Cat 02-07-2008
take a look at the pads that came with my putz 63\"\"
Bob 02-07-2008
When you aren\'t pumping you can play frisbee with your dog.
What is up with the cylinder rod? Is that rust?
CJ36Z 02-07-2008
Hey where is the PM stamp. That sure is a nice machine, what size pump cell do you have? how about \"one touch\"?
bigaboy 02-08-2008
what are these pads made of.
Bob 02-08-2008
I think that the reason that Putz sends out large pumps with small pads is to try and get across the message that just the pads are not enough. They are trying to reinforce the use of dunnage by making the pads small. I think that is a good idea.
The Cat 02-08-2008
..bob reguarding the leg rams it\'s not rust that is the leg it\'s self not sure how it work\'s but we think that it\'s a outer cover...these pads actully measure a larger area then the woodern block\'s and the small pad that comes with the machine.... the pump unit is a 120 and the pads are made of a polyama   it\'s a good job there round there quite heavy
