Rev | 07-03-2013 | comment profile send pm notify |
I know this guy again cant keep it clean And again im a wanna be operator till i get me first 50 m
But when them heads show themselves id love to stop em and gentley chip em This a transcerete i think i remember bvuddy sayin them plastic cups Dont know if that means piston heads BUT Is there a way to stop pistons exactly where you want em
AND
If you got full failure whatever it maybe is there a way to manually shift tube side to be able to clean cylinder |
Trey | 07-04-2013 | reply profile send pm notify |
I think there is a toggle switch on the side of the control box. I think there is one for Auto/Man and one for Left/Right or A/B Cylinder. I dont remeber if there is a manual lever, if there is it, it'll probally be a block with two rubber push buttons on it. |
DIGGER | 07-04-2013 | reply profile send pm notify |
Put the pump into reverse mode, wind down the volume control knob on the panel 50% then turn the pump to the pump on position and at the same time hold the jog switch one side (any side will do) this will stop a piston at the hopper end of the concrete cylinder. Apply water and wash the end of the piston body ... it is steel. |
