excess grease
JohnThomas 02-08-2008
I grease my boom once a month, but how do i get the excess grease out? should i wash it off then grease it? how many squirts should i put in each zert?
Bob 02-08-2008
J.T.
I appreciate operators that hand grease their booms. When they are done they have given the boom a good visual inspection which may catch an early problem.
To get back to fresh, you should get a brush and some rags and some Looooong rubber gloves and clean each joint with solvent. You can then wash the entire boom with good soap & HOT WATER.
If you grease it once a month you need not put more than a shot or two in each zirk. Always wipe the top of the zirk off before you put the grease gun on it; forcing dirt into the pins and bushings is not good practice. After greasing one area wipe any excess grease off with a clean rag dampened with a little solvent.
OR...... ask OE - 3 how he does it; his boom is cleaner than mine ever was. ;~)
shrek52z 02-08-2008
Jt, can\'t help you there, pump has auto greasers. I just passed thru your area, Taking a trip to amarillo.
OE Local 3 02-08-2008
J.T.,
Send me an e-mail ... Its a highly classified technique! LOL :-)
Bob, thanks for the compliment....
Brian
OE-3
