| pumpingdave | 01-27-2009 | comment profile send pm notify |
i run a 07 putz 40 meter and wear out gaskets after only 900 hundred yards or less is there a better gasket out there or did my company buy the cheapest any info would be appreciated |
| bri | 01-27-2009 | reply profile send pm notify |
Do you grease all of your swivel gaskets? |
| truckshow | 01-27-2009 | reply profile send pm notify |
Are using the infamous putz swivel with the tongue...? Cuz if not, they'll leak for ever... I have noticed when changing my swivels, if I try and use a normal swivel gasket from ConForms(w/o the very small tongue) the elbows aren't tight.... Anyone else experience this?? Seems like the clamps on Putzs HAVE to HAVE that special tongue PUTZ gasket... With the proper gasket I haven't had a problem, Approx. 4000 yds and using same gaskets.....Sounds wierd but its true... Anyone else???? |
| typesdubs | 01-27-2009 | reply profile send pm notify |
I like the newer style hard red gaskets. seem to last a lot longer. |
oh yeah, diddo to what BRI said, You do grease em right?? |
| only1putz | 01-27-2009 | reply profile send pm notify |
i've found that a conforms cavity gasket with grease packed in it works good... if you are doing a lot of system pours, you are going to shorten the life of whatever swivel gasket you use i've found |
I can get a few thousand yrds with mine just plain jane gaskets |
| pudg | 01-28-2009 | reply profile send pm notify |
i use regular small tongue gaskets grease ,dont really have any problems,those red gaskets very expensive and they do not seem to last that much longer to justify the xtra expense |
| Weave | 01-28-2009 | reply profile send pm notify |
Grease your gaskets and i put a little oil in my tip elbow before i fold up. It really helps to keep it from siezing up as fast. |
| Bob | 01-28-2009 | reply profile send pm notify |
Make sure that the elbows line up correctly is #1 in how to get good service life out of your gaskets. Tip elbows should be knocked off, cleaned and greased whenever they get tight. |
| TOM@CF | 01-28-2009 | reply profile send pm notify |
The type of elbows can also cause premature wear on gaskets. Some cast elbows out there have 'as cast' ends which are rough & as they rotate they tend to 'chew-up' the ID of the gasket. If the gaskets are 'cheapos' they can go really fast. Times are tough & labor is expensive...Hmm sounds like a quality gasket can be cheaper in the long-run than the cheapo...you think? Grease can help but smooth fittings with a quality gasket are the best answer in my opinion. |
BTW, 'those expensive red gaskets' aren't really that much more expensive than the regular gaskets Pudge. New tool a couple years ago which created a new price. |
| Deuce | 03-31-2009 | reply profile send pm notify |
I run an 05 38-Z and I grease the crap out of them and I change them once every 6 months .
