Getting set concrete out of 3 inch rubber.
Sambo 12-16-2013
Gday guys, Australian concrete pumper here. I just found this site and look forward to becoming a member of the community.
I come here with a question to help a fellow pump owner. Between the combination of a super hot day and a horrible mix of concrete with high dose accelerator, concrete had 90% set in a 60ft length of 3inch hose. (line pump). He managed to bash, shake out and save about half of it, but the rest has set. It has been a few days and he has had not much luck with it. Is there anything that can be done or is the hose gone?
Thanks.
Mister_Perkins 12-16-2013
run the hose over with a truck and chisel the end of it out with an air chisel
crete 12-16-2013
I agree with the above. It works. I drove my hard tire fork lift over my then hung the hose from the forklift and started flushing it out. Didnt damage the hose either. Sometimes low tech works.
AZ pumper 12-16-2013
Ur better off just to junck the hose I don't think there really is a way to clean it with out damaging the inside of the hose
biged 12-16-2013
I lost two 2 1/2 inch hose's last winter,I tried everything I could think of I threw mine away you would be better off.
PEAGRAVEL PRO 12-17-2013
howd you lose them big ed?
79xlch 12-18-2013
Running over the hose scares me.  If you damage it and one day you pressure up and it blows what could happen.  You might save it but at what cost.
Trey 12-22-2013
Ive gotten out some pretty hard concrete with a garden hose with good pressure and a blow out cap. but we did it that day, not a couple of days
