getting ur ball back
kneerick 03-13-2012
sucking ur ball back,I have been doing it the same way for 15+ years with no problems,now a fellow operator is chewing my ass because I wont stand the 58 putz verticle ,I drain out 3 and 4 and reverse the pump several strokes so my thought is only having mud in the 90's of 3 and 4 and only having minimal mud from 2 back to the hopper,1 and 2 are verticle,thoughts welcome..
kneerick 03-13-2012
and we used a sponge and a ball
The Cat 03-13-2012
do it the same way as you with my 63  and the other pumps i've used in the last 20 years with no trouble..
PrariePumper 03-13-2012
If it works then who gives a crap how its done, as long as the end result is the same ... clean pipes!
kneerick 03-13-2012
got a couple know it alls,one guy said I can tell u dont stand it up,lol,he must be able to see into the pipe without taking it apart,jackass
Beast 03-13-2012
I ran a 58 behind a guy who sucked back vertical, he still had build up in every 90, I cleaned all 90s and started doing it my way and for the year I ran it I never went vertical did exactly what you do and never once had a issue.
kneerick 03-13-2012
these too guys are premadonnas,there shit dont stink,one guy wanted to fight me cause I didnt park the pump in the right spot,petty I dont have time for that crap
pumpin man 03-13-2012
What ever works, the guys I work with are great.
murf 03-14-2012
if it works for u then stick with it- perhaps they have to go vertical every time cos theyre too lazy to change the turret gasket!
ruscoe 03-14-2012
why should it be a problem if it works ? The only i time we have to go vertical with any pump is a very badly leaking seal, wear plate to cutting ring distance or being folded up in a z in a building with really crap concrete.
Perhaps there other or former operators have been pulling the balls back at 300 mph ?
b-alto 03-14-2012
They would look foolish standing a 58 straight up just to suck back. Also its dangerous. What if mud falls out or rocks from 150 feet in the air. or worse yet your pump switch get turned the wrong way.
kneerick 03-14-2012
they do stand the 58 verticle
yard whore 03-14-2012
Solve the whole problem and water wash!!!
b-alto 03-14-2012
When i was a beginner i used to stand my 28M straight up to suck back. One time a small bit of concrete fell, Just a small bit and it blew out my front windsheild.. My advice: two round sponges with five gallons of water inbetween. "A" frame. If you must plastic bag the second. But with a good sponge
you won't.
lucky phil 03-14-2012
Its been a while since i read the manual, but if i remember correctly Schwing recomend sucking the boom back with it in the a frame position, or 1 and 2 locked out and 3 and 4 hanging! I have done it this way for 13 years with no trouble.
kneerick 03-24-2012
apparently Im not following procedure
