| b-alto | 08-01-2013 | comment profile send pm notify |
Which grease is better: clear good looking red, clear blue, clear yellow, white, or Dark non see through red or black grease? i learned something yesterday thought i'd share it. |
| old guy | 08-01-2013 | reply profile send pm notify |
I take it, Your clueless? |
| b-alto | 08-01-2013 | reply profile send pm notify |
is that your answer smart guy? |
| Ne-max | 08-01-2013 | reply profile send pm notify |
There are some factors to this question. The Climate where the pump is and what parts of the pump. I dont believe there is a exact answer. |
| xforce1 | 08-01-2013 | reply profile send pm notify |
Curious to know this answer???????????? |
| Dont need one | 08-01-2013 | reply profile send pm notify |
The ingrediants are probably the key issue, call the manufacturer. |
| 180 flyer | 08-01-2013 | reply profile send pm notify |
Agree with DNO. The manufacturer is the best source of info for a question like this. An internet message board is probably the worst. |
| bisley57 | 08-02-2013 | reply profile send pm notify |
The one you use on a constant basis................... |
| crete | 08-02-2013 | reply profile send pm notify |
any grease is better than no grease! |
| service1 | 08-02-2013 | reply profile send pm notify |
Different manufacturers add dye to color their grease but that should not be the factor for picking grease. You need to look at the chemical make up and viscosity. |
| gboom | 08-02-2013 | reply profile send pm notify |
As long as it specifies "NLGI 2", it doesnt matter what color it is |
...some dont like molly..... |
| b-alto | 08-02-2013 | reply profile send pm notify |
Hey guys had three jobs today and drive over 300 miles, up north pumping you get around. Anyway what i learned from my machinest friend who just rebuilt my rock swing arm is, the grease you can't see through is best because its dark from suspended particles of either graphite or molly. Thousands of tiny balls that lubricate and act like little bearings. The pretty red and blue grease is basically just petroleum with color, it just washes away or rubs out. I don't know but it makes sense to me.. |
| Mr.HighRise | 08-02-2013 | reply profile send pm notify |
putzmeister recomends lx1 grease for their grease system since its thinner and wont plug the pots, on schwings lx 2 is recommended and the vogels can handle the thicker viscosity |
| Mister_Perkins | 08-03-2013 | reply profile send pm notify |
who has grease pots??? lol.. I have to manually grease my rig every 100y |
| bisley57 | 08-03-2013 | reply profile send pm notify |
Dont need a grease pot with a Schwing...a Putz gland is much larger,and to keep it right a pot is the only way to go.The booms dont need a pot but it sure wont harm anything as long as they are kept filled and work properly. |
Good grease pulls well,put some grease between your thump and forefinger and open slowly.It will either break or be very stringy.The key is putting your gloves on and picking up that thing with the lever,and use it.Question; On a jobsite which do you use more,your "smart" phone or your grease gun? If you were born after 1973 I think I know which one............. |
