| ruck | 05-22-2009 | comment profile send pm notify |
I 'm having alittle boom trouble.About aweek ago my boom started to move a little slower,Some slower then others.Some sections are moving alot slower then others.Just wondering if you guys think I have a hydro pump going out.Let me know. Jimmy O let Scott know I'm calling him this week. |
| PourItOut | 05-22-2009 | reply profile send pm notify |
try changing high pressure filter,, if it doesnt help, pump getting weak |
| the Turnernator | 05-22-2009 | reply profile send pm notify |
couple of things to look at- if the pump is slowing down also check your hyd-oil temp might be getting warm. drain some oil out of the solinoid line and check for particle contamination. all else fails put a gauge on the pump and make sure its putting out. lots of possibilities good luck! |
| Munir | 05-22-2009 | reply profile send pm notify |
Hello Ruck, First of all check haydralic presser of pump if that is ok. Check main haydralic valve of boom that is fixed on hand block. if some section working good and some not it means haydralic pump is ok. witch section is not working properly check his electronic selonite replace by other section witch one is working good then you will find the different. You can check manual also one by one all boom then I think you will get the better result.
| ruck | 05-23-2009 | reply profile send pm notify |
Thank you guys |
