Help with 39M
thinsplash 05-10-2006
I was wondering if anyone out there has a 39M schwing with the new vector system on it. would be better if it is a detach but any 39m vector would be great to know if someone has one. just want to know if they make it and how many are out there?thanks
Bob 05-12-2006
What does the Vector system do?
Aussie 05-13-2006
Bob go to pump companies tab on this site then into buckeye under equipment sales click on vector control systems you will find all the info there cheers G!DAY FROM AUSSIE
2in05 05-14-2006
The vector system does help.The operators control box has digital readout for pump pressure,pump output,hyd.oil temp., and rpm.These readouts help by keeping the operatorin touch with his machine when not close to the machine.All I can suggest about hose whipping is to keep your trigger finger ready,and pay attention to what is going on at all times.Always clear hose when priming out or restarting,try to monitor what goes into your hopper like excessive water,chain binders,chunks of free concrete,horse heads,soft drink cans,dredge teeth and excessive water.Just imagine yourself running a 100 ft. boom with a 12 gauge shotgun on the end of it,comparitivly very similar in nature.
thinsplash 05-14-2006
thanks for the help guys. i knew they had them. just wish someone knew who had the 39m detach at the world of concrete in the schwing booth.
PONCHOS 05-17-2006
[font=Trebuchet MS]BRUNDAGE BONE HAS 1[/font]
