hopper hinge's
The Cat 06-09-2009
i run a 63 putz...and the hooper hindge seal's never seem to last long if the Vibrator is used for any length of time..i tell the mixer driver to only use it when he has to then switch it off...but guess what they never do....i'm goin to try turning it down just enough to do the job see what happen's....any idea's...
Joe 06-09-2009
You could take it off the grate and remount it to the back of the hopper???
Pump N00b 06-09-2009
Had a Putz with the vibrator on the left side of the hopper. Worked just fine.
Hopper hinge seal, what do you think of now? Pictures?
Raymond 06-09-2009
^^Ya...what Joe said.^^  That works well and the seals seam to last...longer.
Or you could just change the switch to one that doesn't stay on.
cretordog 06-09-2009
I had the same problem on my 47 Putz. turned down the vibrator, and have'nt had a problem for over 6 months.
